Question about Gateway NV5378u Notebook
Waht is the port on the opposite side of the powr button for?
    Guru:
  • 1,705 Answers
Its probably the Kensington lock. Check out the reference guide, possibly on your HDD. If not, here's the URL :-
http://support.gateway.com/s/Manuals/gateway/MUW_SJV50_eRecovery_Ref_Gde_0323.pdf
Posted on May 08, 2010
Where is the battery door on my Jazz DVZ100 located and how do I open it
It's on the side of the camera opposite the flip-out LCD. Push the round button just behind the rubber lid covering the connection ports to unlatch it.
Mar 08, 2012 | Jazz Video Cameras
How do I replace the thermostat on my 1998 Mercury Villager 3 liter?
http://groups.yahoo.com/group/villagerquest/
thermostat must face the opposite of waht you think. Jiggle valve must face up. Use only Nissan or Ford part.
gerry
Jun 04, 2011 | 1998 Mercury Villager
I have lg flatron t705sh monitor,its not responding any thing from few days,just the power button light is blinking continuosly and screen remains blank.what is the problem with it..i have checked the powr...
Either you have a faulty monitor which hopefully the manufacturer can warranty or you have a faulty video card, or an improper connection to the video card. Check to make sure the cord is secure in the port of your computer.
Mar 01, 2011 | LG Computers & Internet
My LG DLE2532W dryer has no heat to dry the clothes....
PULL THE PLUG ON THE DRYER OR TURN OFF CIRCUIT BREAKER. The reset switch is between two wire leads that go to the thermostat and you will probably shock yourself if you try to push the button with the power on. If you open up the right side access cover on the dryer, then you can see the exhaust tube. It is about 5 inches in diameter and (looking through the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port.
Dec 25, 2010 | LG DLE2532W Electric Dryer
Sir, i have just bought a new lg 26ld310 model. I want to connect my PC to it(my pc does not contain HDMI). Waht would be te cheapest and best way to connect my PC? Thanks in advance Regards, Vinamra
Used ur computer VGA monitor cable.Connected to the computer video card port and the other side of the VGA cable connected to the LCD tv VGA video port.This will work fine too.
Dec 02, 2010 | LG Televison & Video
How do i charge my lg bluetooth headset with AC charger. I cannot find an adapter insert on the headset.
HI. You will need to remove the concealment cover on the charging port before you can connect the charger. The cover is on the opposite side of the volume button. It will have the initials "PWR" on the cover. Pull that off to expose the charging port.
Aug 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
There is a loose piece inside my Magellan 4000 Navigation system. The little connection piece is loose inside. How do I open the system up?
hi, see directions below..
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
this should help you....let me know if you need more help or info
Ill assume you have either a 31XX, 4XXX model since those are the ones that are alittle harder to get apart then any other Magellan. Read below what I have replied to others with this question.
You have to be careful taking them apart or youll Break the power port and the head phone port right of the board And it will probably screw the board up. had a few were ppl tried to Take them apart the wrong way and broke the tracers right off the board (now there junk)
Note: always start on the side opposite the power port
Anyway, after the screws are out, use your finger nail if you can,(that's what I use) if not get yourself a very small flat screw Driver (jeweler type) and starting from the side opposite the power port (pictures below) and Head phone port (start on the side the power BUTTON is on, starting at the bottom, Slip it along the seam where the front and back of the case Meet, but don't force it down inside the 2 halfs, you want to just put the blade In far enough so it slides along the seem and that its is separating the 2 just enough to unlock the tabs from Each other see the pics There are 6 taps to break free..2 on the top, 2 on the bottom and 1 on each side....don't worry about the on on the port side. Just tip the back of the case upward and that side will come free on its own. When you put it back together, the port side goes in 1st. Tip the rear of the case up and slide it in under the ports and then lay the back down on to the front half and it will snap together.
bill
May 09, 2010 | Magellan Maestro 4000 GPS
Hi. 91 bronco no stoplites or hazards.powr out of fuse box no powr at sockets. tail lites wurk fine. i tried 2 run makshift grd but no lck.directnls r fin and hazards wurk in front, its like both rh and lh...
heck power on both sides of brake light switch with pedal depressed.if power on 1 side only replace brake light switch.if no power to brake light switch check turn signal switch.
Jan 02, 2010 | 1991 Ford Bronco
The paper was pulled out to clear the paper jam opposite the standard path of travel. Ever since I can not clear the error Carriage Jam. HELP
Dont worry,
Now open the front access door and manually move the cradle left to right 10-15 times gently (cradle carries printheads in it which moves left to right in order to print.
>>Clean the rollers with the lint free cloth and lttle bit of water.
>>Do a pwr drain(take out the powr cord and press and hold the power button for 20 sec and release it and plug in the cord back.
>>Do a partial reset take out the powr cord and press and hold the # and the 3 button and holding both plug in back the power cord.Release the buttons once the printer powers on.
>>If still its not working ..Do a semifull reset take out the powr cord and press and hold the # and the 6 this time button and holding both plug in back the power cord.Release the buttons once the printer powers on.
>>If doesnt work......call Hp and they will replace the printer for you.
Let me Know.
Best wishes,
Suvrajit
Oct 03, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Gateway NV5378u Notebook Logo
132 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
