Question about Dryers
My dryer makes a groaning noise on each rotation ... especially the load is very light. I manually turn the drum clock-wise and it seems to help for while. If we add more clothing to the load it also help. What could this be
  • 10,319 Answers
The belt that rotes the drum has a belt tensioner that keeps the belt tightly fitted on the drum. You may have a dried up belt or a dried up bearing in the roller for the belt tensioner. An inspection can be done by removing the top and front panel of your dryer to see
Posted on May 08, 2010
Why it doesnt start and make a long noise
Grandson just had this problem with our dryer. he was setting the timer by turning it counter clock wise, all he got was a buzz. When it set it clock wise it worked find.
I know this is a simple fit but worked or him
Randy
Apr 29, 2014 | Siemens WFXD5200UC Front Load Washer
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
My maytag dryer model lde5914acm makes a 'ker-thunk' noise as the drum rotates. It makes the noise approximately every rotation of the drum. It has been getting progressively worse over the last 10 loads....
Dave,
First off I would suggest a visual inspection of the inside of the drum. Also try to observe it while it is running to see if the drum is off balance. That can happen if a large or awkward load is put in the dryer. If that doesn't yield any results then it may be time to check things out inside the machine. I would strongly recommend disconnecting power from the unit, especially if you are unsure of what you are doing. It just isn't worth the risk. Look for anything that seems wrong or out of place. Aside from that, I can't be of too much help without being there.
Dec 16, 2009 | Maytag Dryers
Loud bang during dryer rotation. front loaded dryer. dryer is six years old. bang is with evry rotation of drum.
not nkowing what brand, I would guess its a maytag or one of their brands. It sounds like a screw that mounts one of the paddles inside the drum has backed out and is now poking out the out side of the drum hitting the cabnet as it goes around. Un plug it , pop the top open , rotate the drum clock wise by hand slowly to see if a screw is standing up on drum.
If its a whirpool dryer with the lint filter inside the door, the top cabnet is dented down, hitting the drum.
someone sat on the top, bent it down.
Nov 21, 2009 | Washing Machines
Drum makes noises as it turns
Your rollers may be bad. The drum rotates on three or four rollers. You would have to remove the front of the dryer and then pull the drum to see them. If you decide to replace them, it would be wise to get the felt kit that attaches to the drum as well. Good luck.
Apr 17, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Sep 17, 2007 | Estate EED4300SQ Dryer
Wd860
setup error [check eeprom]. Call an engineer as you will have a 5 years parts cover
Jul 03, 2007 | Hotpoint Ultima WD72 Front Load...
Dryers Logo
79 people viewed this question
Top Dryers Experts
