Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
THE RIGHT REAR ELECTRONIC IGNITER DOESNT WORK
  • Maytag Master
  • 8,220 Answers
All of the igniters are connected together. When power is applied they all get activated and all burners spark. If one aint working either the ire to it is off, or the igniter have grease on it and therefore cannot get a good ground, or the hole beside the igniter is clogged and thus the gas won't ignite. This first video shows how they work and the second one is very important because it shows how to keep from damaging the stove while attempting repairs
Posted on May 08, 2010
Why would the left burner activate the right igniter?
Sometimes a lot of the holes in the burner get plugged. I use a toothpick to clean them out.
Hope this helps.
Mar 20, 2015 | Kitchen Ranges
On a chevy traverse i cant get the windows to work. i cant get key out of ignition, and right rear blinker doesnt work
Fuse under the right passenger dash. Fifth up on the right (blue 15 amp). It is called BCK/UP/STOP. All the same symptoms short in wiring harness for the trailer package caused the windows not to function, the right rear turn signal had no power, and the key was stuck in the ignition.
Dec 02, 2012 | Cars & Trucks
Hello, the front left indicator is not working neither flashing at all. The rear left indicator just stays lit and does not flash. The right indicators work fine. I have bought the correct bulbs and...
Concentrate on the front indicator.
With a meter check you have an intermittent supply with the ignition on and left indicator selected.
If its ok, it will be an earth (ground) problem. Check using a temporary earth wire from the indicator unit to the chassis.
If no voltage found at indicator bulb, trace the supply cable back to source.
Sep 23, 2017 | 2007 Yamaha Ybr 125
Does a 1989 ford escort have points
No.
The 1989 Escort uses an Electronic Ignition Control Module.
Jan 06, 2011 | Ford Escort Cars & Trucks
96 pontiac sunfire use chiped keys?
they don't have an electronic chip, it is a piece of resistive wire near the base of the key shaft, u must read that resistive value to get the right key.
Jul 02, 2010 | 1996 Pontiac Sunfire
89 Toyota Pickup right turn signal doesnt work just buzzes
check all bulbs,inspect sockets for corrosion,rust ,or sighns of overload.follow wires and check connectors if all good ,replace the flasher ,,if that doesnt fix it ,the blinker switch in the steering coulmn would be next
Sep 22, 2009 | 1990 Toyota Pickup
Need Radio wiring diagram 2004 chevy silverado 2500hd (oem plug)
Left Front Speaker(+) TAN ; Size: tab_tech.gif Left Front Speaker(-) GRAY ; Size: Right Front Speaker(+) L GREEN ; Size: Right Front Speaker(-) D GREEN ; Size: Left Rear Speaker(+) BROWN ; Size: Left Rear Speaker(-) YELLOW ; Size: Right Rear Speaker(+) BLUE ; Size: Right Rear Speaker(-) LT BLUE
Yellow -ignition
Orange-Constant +12 volts
Black - ground
If you need more info, please ask.
A rating is appreciated.
Jun 13, 2009 | Car Audio & Video
Burner will not ignite.
facing the spark ignition, the burner has small holes that need to be clean, those holes are going down on the side of the burners, take a look a the ones that are working so that you can see the small flames going down facing the electronic pilot call the spark ignitiong, you can take a safety pin or a paper clip and clean them. many times the ignition is between the front and rear burners, it's where the spark ignite the burners.
Dec 13, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
My wolf rage doesn't light anymore by turning a nob
some models have one gas pilot for 2 burner front and rear and there is a small pipe that goes front the burner to to the pilot, the burner has small holes facing the pipe the goes to the pilot that's where you take a paper clip or a safety pin and clear or clean the holes, the same thing on the electronic ignition, but some electronic ignition they have a spark right nest to the burner and by looking at the other burner that are working you can see where it's sparking, and clean in between the burner and the spark.
Dec 12, 2008 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Wires came out of the plug
From Pioneer Electronics Support Website Yellow - To terminal always supplied with power regardless of ignition switch position. Red - To electric terminal controlled by ignition switch (12 V DC) ON/OFF. Black (ground) - To vehicle (metal) body Blue/white - To system control terminal of the power amp or Auto-antenna relay control terminal White - front speaker left + (positive) White/black - front speaker left - (negative) Grey - front speaker right + (positive) Grey/Black - front speaker right - (negative) Green - rear speaker left + (positive) Green/Black - rear speaker left - (negative) Violet - rear speaker right + (positive) Violet/black - rear speaker right - (negative) Best of Luck.
Sep 09, 2007 | Pioneer DEH-P3800MP CD Player
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
287 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
