Question about Hotpoint RVM1325BW Microwave Oven
It does not turn on when start pushed. it just clicks and only the timer runs.
    President:
  • 949 Answers
This symptom would lead me to believe the high voltage relay contacts on the control board are bad.
The cost is about $135.00 for the control.
Let me know if you need instructions on how to replace it.
Posted on May 08, 2010
When I set timer and press start the timer runs for two seconds and turns off. The turn table nevre starts
take it in for service or just buy a new one . probably cost more t fix than a new one would be
May 08, 2015 | Microwave Ovens
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
Oct 09, 2013 | GE JES1142SJ Microwave Oven
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
I have maytag advance cooking system(electric) and the oven will not work.The timer to set the oven and the time is not lighting up but the stove is working.any sugestion
try resetting the clock. If it is digital, push the clock button and then the number buttons untill you have the proper time displayed...then push the clock button again. If your clock and timer are manual, try pushing in the clock lever and turning it 1/4 turn. If this works it would indicate that your timer has a start and finish time and that the oven is not working because the clock has rotated around to the finish time.
Sep 09, 2011 | Microwave Ovens
Everything works but unit will not come on to heat If I push start it clicks and timer starts but unit does not come on
The most likely problem is caused by a defective magnetron, "heats food" It is cheaper to replace that microwave oven than have it repaired.
Jun 04, 2011 | Microwave Ovens
Panasonic microwave model #NN-SD697S stopped working. Timer works for 2-3 seconds without motor running(heating) then turns off. Push start button, nothing happens.
@William Miller - where are you located if i'm interested in your help with the microwave repair? I'm having the similar issue with the Start buton not working for my Panasonic NNSD697SS. Thanks
Feb 10, 2011 | Panasonic Microwave Ovens
Model# FMV156EMA over the stove microwaive. We set the timer and when you push start the light on the inside comes on, but the microwaive will not start, the timer also runs but it does not actually come...
You have a failed bottom door switch, or that switch's mount is broken or misaligned.
See the service manuals here and here and this text file.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 22, 2011 | Frigidaire Microwave Ovens
Frigidaire FM156DSB 950w #7G63610032 light and timer works but microwave will not come on. When you push start it just clicks and does nothing. You can push up on the door from the bottom and microwave...
I have the same problem with ours! The light will come like it should but the microwave will not start until we hit the upper part of the door handle. Any advice?
Jan 21, 2011 | Microwave Ovens
GE Microwave Doesn't Work, Timer Ok
More than sure, the door micro switches do not work properly, they should be carefully checked.
Sep 24, 2017 | General Electric Microwave Oven
Hotpoint RVM1325BW Microwave Oven Logo
61 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
