Question about Palm Treo 750 Smartphone
Touch Screen Lockup
My touch screen is locked up. I reset it and it boots to initial window and says tap, after that its locked. Can you assist?
  • Palm Master
  • 13,433 Answers
Possibly the touchscreen is broken?
a hard reset might solve it, but you would also loose all the data in your device.
Posted on Apr 21, 2008
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
How do i unlock my ipod touch
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
Screen dissapears after activating call
possibly solution
1.hard reset your device
2.otherwise it maybe hardware issue (touch screen problem)
for : hard reset on the start screen tap -> button then tap setting then about phone, then tap reset your phone and tap yes.
touch screen issue : you need to take to some technician to disassembly to touch screen and reassembly again if with this not solved you will need to change the touch screen. i think this will help you.
Jun 20, 2012 | Nokia Lumia 710
Hp pavillon tx1000 12.1 inch touch screen cursor stays at bottom left hand conrner
Clean the screen with a clean soft cotton cloth is the step #1
Step 2:
SEE FULL instruction HERE
Calibrate the touch screen
The command buttons and fields are displayed on the screen image at specific pixel points. To initiate a response, the touch screen interface needs to recognize exactly where a fingertip or pen touches the screen relative to the pixel position of the display. Each user has a slightly different hand-eye coordination response. Calibrating the touch screen allows the interface to compensate between where the program is expecting a touch and where the touch actually occurs. To calibrate the touch screen, place the tablet notebook in the desired orientation and do the following actions.
  1. Click or tap Start > Control Panel > Tablet PC Settings to open the Table PC Settings window.
  2. On the General tab, select the option to display the menus in either the Right-handed or Left-handed position.
  3. On the General tab, select the desired screen orientation from the drop-down menu, and click or tap Calibrate . Follow the instruction to touch the screen at the specified points. Repeat this calibration action for all four of the screen orientations, then click or tap Apply .
  4. On the Handwriting Recognition tab, select the Use the handwriting personalization option.
  5. At a later time, you can return to review the Go to Pen and Input Devices and Go to Input Panel Settings options to make using the touch screen to control programs and input text easier and more accurate.
Compare your version of the firmware to the latest one at HP offical site HERE
Always get the latest firmware to avoid problem.
Always keep the screen clean!
Jul 11, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
Feb 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Touch Screen fails to work
get it serviced?
my guess, damaged screen.
most shops would touch any Ipaq.
why not ask on a real HP forum?
my guess, the only hope for old Ipaq
http://h30434.www3.hp.com/
May 10, 2017 | HP iPAQ hx2190 Pocket PC
Imate pdal touch
my mobile was in locked condition, and now my touch is not working..not even a single tap is working on mobile screen. i did soft as well as hard reset but every time the unlock screen appears after boot process. i can only press the unlock button on screen from the left button on mobile and cant press Unlock again because it is on the screen.
I believe in this situation, only two options can be used, One is to attach a Keyboard, or to access the mobile screen through any software on PC.
Nov 11, 2008 | i-mate PDAL Pocket PC
Garmin 360
Have you tried performing a soft reset by pressing the reset button on the back of the unit, then turning it on again?
How about a hard reset?
With the unit powered off, hold your finger on the upper right- hand corner of the touch screen and tap the power key. Continue to hold your finger on the screen until you get a warning message. Tap "OK" to reboot the GPS.
Please let me know if I can be of further assistance to you.
- Jim
Feb 15, 2008 | Garmin nuvi 350 GPS Receiver
Palm Treo 750 Smartphone Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
