Question about Kenmore 62602 Electric Dryer
There is no heat
The dryer still runs through all cycles but there is absolutely no heat.
Are there fuses somewhere that can be changed.
  • 10,319 Answers
Check the exhaust vent tubing throughout. If clogged up with lint the sensor will shut the heating completely off all the time till cleaned
Posted on May 08, 2010
Maytag dryer temperature fluctuates. replaced the thermal fuse 2 weeks ago. this fixed the problem but the dryer now gets a lot hotter and cooler than before. all the clothing is coming out wrinkled.
change the cycling thermostat and when was the last time you cleaned out the dryer and vent line?if it's gas it should be done at least once a year electric every 16 to 20 months because you don't have an open flame in there like a gas dryer but you either have bad air movement or the cycling t-stat is bad and if you had to change out the thermal fuse is a definite sign of this,if your clothes have been taking longer to dry you have a block somewhere,you can try removing the vent line from the back of dryer and run it to see if it helps and check the duct that the lint filter slides down into for lint buildup,all a dryer does is spin,heat and move air if it's blocked it will pop the thermal fuse.
Nov 26, 2017 | Maytag Dryers
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
Why do clothes take a long time to dry even if dryer is heating?
Sounds like there is still a blockage somewhere, maybe near the filter screen.
Jan 22, 2015 | Whirlpool Dryers
Dyer wouldn't run. Thermal fuse was replaced. Ran one cycle and stopped. Thermal fuse is again gone. ???????????
If your thermal fuse keeps popping, you may want to ensure you have the vent cleaned out, you may have some sort of restriction somewhere in either the duct,
or the machine. As you know the thermal fuse, protects the machine from over heating.
Check that you have the proper voltage to the machine,
Ohm out the heating element to ensure you have voltage right there, then ohm out your Cycle t-stat, it may not be working right either.
Oct 20, 2009 | Whirlpool LER4634J Electric Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
Dryer runs fine but no heat
change the fuse in back of the dryer
Jun 23, 2009 | Kenmore 73952 Gas Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer heating element
There is a fuse in the dryer for the heat.
Before tearing into the dryer, make sure the power getting to the dryer is absolutely correct. (check power with the dryer running) Even with incorrect power to the dryer. the drum will still turn but there will be no heat.
Many a person has paid for expensive service calls for the problem you are having only to discover by the servicer that there was nothing wrong with the dryer but had bad power to the dryer......
Jun 15, 2008 | Whirlpool Dryers
Kenmore 62602 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
