Question about BenQ PE8700 Multimedia Projector
BenQ PE8700 DVI problem
I have had an ongoing problem with my BenQ PE 8700 projector. I use a DVI connection on the projector to connect to my HD Cable box. It will work for a while but eventually stops working. I will get the message DVI not supported in the lower right hand corner of the screen. I can reset the cable box and alter the setup in the cable box to work on the DVI setting then the picture will come on the screen for a couple of seconds then go off. I use the component connections for my dvd player so I don't want to switch it back and forth just to get it to work.
  • badgerfan Mar 30, 2008
    I have a similar problem with my BenQ PE8700. I also have my cable box coming in through the DVI connection, and my DVD/other sources through the component inputs. When I first turn on the cable box, the picture will show for a couple of seconds and then go black. If I turn the cable box off and then back on, the same thing will happen. I have found that if I unplug the DVI cable at the projector and then plug it back in a few times, the picture will eventually stay on. Needless to say, this is very frustrating. I would like to know if there is a firmware or other update available to fix this problem.
  • 563 Answers
Hi guys
All that needs to be done is a firmware upgrade.
This can however only be done by a BenQ Approved Service Provider because if the person doing this makes a balls-up the Projector will be dead as a doornail.
Posted on Apr 01, 2008
SOURCE:
Can I replace the fan and how do I do it for a Benq PE8700
If the lamp LED flashes red, it indicates that the front cover is not installed properly, the fan is not working, the translation board is defective or the ventilation holes are blocked.
The first thing I would try is to remove the lamp assembly and try reinstalling. (Did you purchase a genuine BenQ lamp assembly)?
If ok, you can download a service manual here (but be advised, this is not for the unqualified. You should seek repair through your dealer).
Elektrotanya for electronics experts
Jun 16, 2017 | BenQ PE8700 Multimedia Projector
Won't broadcast in hi-def with component cables
I have a BENQ PE8700 also. Charter Cable just replaced my Hi Def Cable Box and now I only get the non hi-def channels. I get the sound on the Hi-Def channels only. My projector is hooked up with the DVI Cable. Did you ever find out why you were not getting HI DEF?
Aug 07, 2010 | BenQ PE8700 Multimedia Projector
BenQ pe8700 projector ir sensor replace or repair
unless you dropped it, there is no damage to the sensor. it might just be dirty. blow the dust out of the projector with canned air. if there is physical damage, just replace it. if you're sure the remote works but none of the sensors do, it's a main board problem.
Oct 22, 2009 | BenQ PE8700 Multimedia Projector
Rest benq pe8700 projector
if the lamp comes on, hold the exit button down until the osd comes on. press enter, then the right or left arrow button to reset it, then the exit.
Oct 02, 2009 | BenQ PE8700 Multimedia Projector
BENQ VA321 REMOTE CONTROL
Hi there
A universal remote would do the job , as long as you make sure that the Universal Remote can learn IR codes which it uses to control the Projector.
Sep 25, 2008 | BenQ 98J2032B01 PE8700-REMOTE Projector...
Dvi input problems
Hi 1ivans
I would suggest that you should firstly try another DVI cable.
If this doesn't work , then the comms board will most probably need replacement.
Apr 27, 2008 | BenQ PE8700 Multimedia Projector
BenQ PE8700
Nothing yet , still awaiting feedback from BenQ Factory
Apr 15, 2008 | BenQ PE8700 Multimedia Projector
BenQ 8700 projector solution
Hi Rick
The upgrade is the same one used for the BenQ PE8720
Whoever told you this obviously did'nt know this.
You'll be needing Flashloader and the RS232 cable that came with the Projector.
It is absolutely cheeky of them to suggest that you should just use the Component input for all your applications on this Projector.
Make sure they understand that this was a top of the range Projector when you bought it and that it is not a good enough answer.
Apr 02, 2008 | BenQ PE8700 Multimedia Projector
BenQ 8700
I had a similar problem with my Benq 8700+. The aspect ratio would show in the R low corner on changinbg resolutions, and would close down to a single line ("anamorphic" for example) which would remain on the screen. I checked the manual (useless) and went through all the set up screens (again useless). In despiration, I decided to try to unplug the projector and did so for 30 seconds to allow the charge to drain from the circuits powering the chips in the 8700+. Upon returning power and restarting, the screen resolution appears/disappears properly once again. Give thjis a try.
Sep 29, 2007 | BenQ PE8700 Multimedia Projector
BenQ PE8700 Multimedia Projector Logo
254 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
