Question about HP DeskJet 932c InkJet Printer
I have a major paper jamb The printer tried to feed about 12 sheets at once
  • 4,041 Answers
Hello there
Take out what you can see first.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
Photo paper jams
Feed only one sheet at a time and select the paper type properly in the menu. HP are notorious for paper jambs with thick paper because the paper path folds back on itself when using front loading trays. If the printer has a rear paper feed capability, use it to make the paper path straight. EPSONs do not jamb as much, but the ink is far more expensive. Reading the on-line instructional manual from the web-site may provide a paper settings solution and calling HP's toll-free number may help too.
Aug 27, 2012 | HP Deskjet 5400 Series
Printer is not print properly & paper jam problem. how repair the printer &how to troubleshoot the printer &how check out ,which part have problem.
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message.When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 28, 2011 | HP Office Equipment & Supplies
Printer will not feed paper straight grabs one side and pulls the paper crooked and crumples the paper
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    Hp deskjet 5550 is always had a paper jam. what do you think is the problem of my printer? what is the possible solutions?
    When removing a sheet of paper from a jambed printer, you need to be careful to slowly remove the paper without tearing the paper. This could lead to a tiny piece of paper being left behind and this will cause other paper jambs.
    When this happens, the printer may need to be dismantled to remove the paper.
    The other cause could be that there is uneven pressure across the rollers or dirty rollers which causes the paper to feed through unevenly and results in a paper jambs.
    Check the printer for pieces of paper near the rollers and gears.
    Clean the rollers, make sure there are no deposits on the rollers.
    May 26, 2010 | HP DeskJet 5550 InkJet Printer
    Paper not feeding into printer: pulls to the right and jambs
    Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
    Worth a try, as I have fixed a number of printers this way, saving costly repairs.
    Hope this helps. Bud
    Dec 30, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    Paper jambs in the feed. The right side seems to pull down first then just jambs up.
    Solution: Remove foreign objects from Rear Tray MP210
    Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
    1. Power the printer off.
    2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
    Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
    Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
    Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
    1. Close the scanning unit (printer cover).
      Caution: Be careful not to pinch fingers when closing the cover.
    2. Power the printer on and confirm that the printer operates normally.
      Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
    And
    Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
    If paper does not feed correctly, perform the following to clean the paper feed rollers:
    1. Open the Printers folder.
      - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
      - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
      - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
      - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
    2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
    3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    1. Remove all sheets of paper from the rear tray, then click 'OK'.
    2. Confirm the following message, and click 'OK'.
    1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
    6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
    Note: The following message is displayed when the paper is fed and ejected.
    1. Click 'OK'.
    Roller Cleaning is completed.
    Cyber Kaka
    Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
    HP DeskJet 932c InkJet Printer Logo
    43 people viewed this question
    Seeker5211
    Seeker5211
