Question about Walkera #4 1: Guiding Ring
How do I fit part 9061-16
I can't work out how to fit new part 9061-16
My ford fitted sat nav system has stopped working batterys in controller leaked fitted new batterys but still not work any suggestions please
Try cleaning, scraping the battery contacts and then put a little petroleum jelly on the contacts and reinstall batteries. If they leaked a bunch then you may have a copper trace or a wire corroded in two.
Jan 03, 2015 | Ford Cars & Trucks
I keep getting " fit printer head " message when it is fitted and I have 2 new cartridges of colour and black and it worked fine last week
Hi Pete,
Ideally it should not give this error however there are few steps that can fix the issue.
I would like to direct you to a link that will be helpful for you in many ways to resolve most of your printer issues.
Click on this link -> Link
Regards,
Sean
Sep 16, 2012 | Canon PIXMA iP2000 InkJet Printer
I bought a new wheel bearing and it comes with a brand new centre nut.I have a socket that will fit the new one but will not fit the old nut that is still on the car.
It shouldn't matter. Some times after market parts are not exactly the same as OE parts. But will work just fine, and sometimes better than the OE part. My advice is just find the right wrench to fit the old nut.
May 03, 2011 | Pontiac Sunfire Cars & Trucks
Golf low beam doesnt work but high beam does high works on both settings
check fuse first, then, fit new bulbs,then, if that dont work, fit a new column switch arm.(high beams have a relay,low dont.)
Jul 26, 2010 | 1995 Volkswagen Golf
The right wire came loose (i think) and the right headphone isn't working unless i fuss with the wire. is this fixable?
Depends where the break is in the cable, if middle to near the plug, you can cutt the cable and put a new plug on. But the closer you get to the headphones you will need a new cable and it will have to be fitted inside the shell.
If in the middle you can extend with an extension cable, after fitting a new plug. If you have to fit a whole new cable, to gain access take off the Ear Pad(s) and remove any foam, you should then see access screws.
If you don't know how to fit a new plug, let me know and I will explain.
Apr 08, 2010 | JBL Reference 410 Headphones (Black)
No timer
Yes sorry to say that your oven wont work you will have to have a new timer fitted, but first make sure that having a new timer fitted is not more expensive than buying a new cooker
Sep 06, 2009 | Ovens
Wii Fit board not staying on
Best suggestion is to make sure the game is fully loaded before pressing the power button.
If it's not working, make sure you press the red sync button on the Wii Fit Balance Board AND the Wii Console.
I know you tried new batteries, but make sure they are really NEW batteries (My experience is that the alkalines work best).
If it still doesn't work, then you may need to contact Nintendo direct.
Apr 08, 2009 | Nintendo Wii Fit for Wii
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Walkera #4 1: Guiding Ring  Logo
67 people viewed this question
Top Walkera Toys Experts
ray gallant
Are you a Walkera Toy Expert? Answer questions, earn points and help others
