Question about Kenmore Washing Machines
11027086603 HAS F2,C5,C6,C9 CODE WHERE DO I GET AN
KENMORE ELITE WASHER 11027086603 HAS F2,C5,C6,C9 CODE WHERE DO I GET AN ERROR CODE LEGEND?
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Depending on how fritzed your drain pump is this may or may not work. I've been using HE detergent because it is supposed to cause fewer suds. However, apparently is causing more suds than needed. I need to use only a couple tablespoons? If your clothes are not dirty enough for the soap to grab onto then extra suds are the result. The repair guy said we had an excessive amount of suds in the system and this affects the sensor and causes the drain pump to run and run and run until it shuts off from overheating. This is why we get the F2 and/or suds error code. He said once a month run the machine on the hottest water cycle with a cup of bleach (no clothes). This will clear out any suds build-up and is cheaper than Afresh which works, too, (but smells cleaner than bleach). After sitting for a day our pump started working again (yay!) It also stopped making the horrible loud sound. So glad I do not have to replace the pump!! yet...(knock on wood!).
Posted on May 13, 2009
jan mczeal
  • 632 Answers
SOURCE: Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Posted on Jan 20, 2010
jsrock516
  • 5911 Answers
SOURCE: f2 code on kenmore elite he3t washer
"F02" is a Long Drain error. This is usually an indication of an obstruction somewhere in the drainage system, or a failed drain pump. In most cases, the drain pump reservoir just needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage these small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and let me know if you have any further questions. I hope you find this information helpful.
NOTE: "SUD" is a suds error detect that can commonly occur in conjunction with the "F02" error. This is a result of too much air being detected in the drainage system. In most cases, correcting the drainage problem will corect BOTH error codes.
Posted on Aug 10, 2010
SOURCE: Sud and F35 error in my kenmore elite h5 steam
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Posted on Aug 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: f2 error
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Why does my kenmore elite washer keeps beeping when it reach the last 2 minute?
If you have an error code (F2) in red letters, the answer has been posted.
The Tinker
Nov 30, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
ERROR CODE F1 IN KENMOR WASHER MACHINE MODEL 11027086603
What F1 means, is the you have a communication error , you need to unplug the unit for 2 mins. What might have caused this might have been a power glitch
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
