Question about Microsoft Windows Media Player
How to save songs to USB using windows media player
    Sergeant:
    Champion:
  • 236 Answers
Just use the explorer to locate the files and then select the desired files right click and then select "send to" and select the usb drive
Posted on May 08, 2010
  • 88 Answers
Hello Sir,
If by "USB" you mean USB Stick (pen drive).
Then after plugging device into USB port, open "My computer" then find it as removable device, open as a normal folder and just drag and drop files in it.
Same you do with all new mp3 players and so.
Cheers,
Mike
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
How to do playlist on the s100
Hi, You can do play list from your PC. By connecting your MP3 player to the PC through Usb cable..
Things You'll Need:
* Computer
* Media player
* Digital music files
Creating a playlist on your computer is an easy way to organize your music. Playlists allow you to organize music by different artists or different genres. More advanced playlists can even sort your music based on when it was added or how often you play a particular song. Creating a playlist is an easy task regardless of the media player you use to play your music.
Determine what songs you would like to add to your playlist.
Create a new playlist in your media player. Depending on your media player, this step will vary. There is usually a "Create Playlist" button that you can click to create a new playlist. In iTunes, this button is on the bottom lower left corner. In Winamp, click the "View" menu and select "Playlist Editor".
Select the songs that you want in your playlist from a new Windows Explorer window. If you are using a Macintosh computer, select the songs from a new Finder window. You can hold down CTRL to select multiple tracks. Drag and drop these selected songs into the new playlist you have just created.
Save the playlist you have just created. Most media players have a "Save Playlist" button. Other media players such as iTunes will automatically save the playlist for you when you first create it. In Winamp, click the "Manage Playlist" button in the bottom right corner. In the following context menu, click "Save Playlist". Name the playlist whatever you want and then choose where you want it to be saved.
Have a nice day....
Feb 19, 2011 | iRiver E10 Digital Media Player
I got some song that i download from the internet i stored it bt ive lost all my songs that i rip in the window media player need to know where is it stored?
where di u store it ?
search using windows search....
give this comand in search string depending upon what file u saved at as
*.mp3(for mp3 file
*.wma(for windows media file)
*.rma(real media file)
etc
Jan 16, 2010 | Electronics - Others
On my computer it will not let me download songs to my player
You can use the following two metheds:
  • **Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder; available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
  • --**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Dec 06, 2009 | RCA M4204 MP3 Player
I cant get my coby mp 815 to pull up its music manager on my new computer, I pluged it in, but it just plays whats already loaded on it? whats the music manager?
If I was you I would use either Windows Media Player or Drag and Drop your files to your player. If you choose to use Windows Media Player you will have the same functions that you will have with the coby music manager. Here is the following ways to add music and files to your player if you choose the above ways to add music:
**Drag and Drop**
Oct 31, 2009 | Audio Players & Recorders
I lost my players insallation CD and can't get my player to work on my computer. what can i do now?
You can use Windows Media Player or Drag and Drop your files to your player. Here is the instructions as to how you can use either of the above:
**Drag and Drop**
Oct 31, 2009 | Philips GOGEAR SA6045 MP3 Player
How do i download the software
You dont need to software to load Windows Media Player if you are using Microsoft Operating System. If you are using a Mac then you can drag and drop your files here is how to do that:
**Drag and Drop**
Oct 28, 2009 | SanDisk Sansa c200 MP3 Player
I need to find an installation program to switch my zen nano to vista from xp
try here first and if that doesn't work you should be able to load it using the drag and drop method
support.creative.com/kb/ShowArticle.aspx?sid=14186
heres the drag and drop/windows media player options
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
Oct 03, 2009 | Creative Labs Zen Nano Plus MP3 Player
How do i download music onto sony walkman if i dont have windows media player 11
try these methods
and any windows media player should work
**Drag and Drop**
Jan 22, 2009 | Sony Walkman NWZ-S616F MP3 Player
Cannot put songs onto mp3 player
i can not download music to my mp3 it is so hard every time i do it it do not go.
Jun 25, 2006 | Gateway DMP-X20 MP3 Player
Microsoft Windows Media Player Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
