Question about Electrolux Guardian Bagged Canister Vacuum
My Electrolux guardian C135 vac has lost suction. replacing the bag does nothing. removing the HEPA filter has no effect - what do you suggest? Will a replacement HEPA filter make any significant difference?
  • 50 Answers
No you have a clog in the hose, wand or at the power head. Remove the hose wand and power head from the the vacuum. Turn on the vacuum, put the palm of your hand over the hole in front, you should feel plunty of suction. Then replace just the hose and put the palm of your hand over the end of the hose. If you do not have suction the clog is in the hose. You can try putting the hose on the blower port to blow out the clog or use the wire from a coat hanger. If you have suction, then add just the wand and repeat. If you have suction, then the clog is in the neck of power head, you will have to use a coat hanger to clear it.
Posted on May 08, 2010
My vacumn won't pick or suction up and bag is not full. I cleaned out the hose checked and belt running I have no other answer please help. It's an upright lux guardian
The output filter on that unit is HEPA and traps all particles. You need to clean or replace that filter because the airflow cannot leave through it and it wont develop suction.
Feb 06, 2015 | Vacuums
How do I change the HEPA filter?
Firmly grasp each side of the HEPA filter and pull up with a quick snap. It will come right off. lay new one in place and simply "pop" back on.
With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Hope that helps! Mick
Sep 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
Electroluxl modelel6984a how to access cod reel
Turn Guardian on it's back, remove all screws from around the perimeter of the base, turn vacuum over on its' wheels, and pull up on entire casing (after removing HEPA Filter on top). It will come off but do so gently as to not disturb original parts settings inside. With 30 yrs. experience dealing almost exclusively with the original Electrolux, I have a legitimate store front business and do service by mail at a reasonable cost if interested. mickeymackmark1@yahoo.com
Jun 16, 2014 | Electrolux Guardian Bagged Canister Vacuum
How to remove electrolux guardian hepa filter
Open gadget compartment, remove all gadgets or attachments and the hepa filter will be below the vented frame...look next to the end with the hose and you'll see two spring clips (part of the vented frame) and squeeze them to allow the vented frame to release and move upward. This will expose the filter. Reinstall in reverse.
Mar 14, 2013 | Electrolux Guardian Bagged Canister Vacuum
How do you make it blow air out? trying to make air blow out,i have the hose that has controls on it. will work to **** up but when i put it to blow out will not come on.
The Guardian Canister vacuums have a blow port under the filter. So you need to remove the filter (on the Guardian Ultra, you have to open the top of the vacuum) by lifting it up the forward. Then disconnect the hose from the normal suction end of the unit and plug it into the blower port. Now turn on the vacuum. If the hose is clogged, position the other end of the hose at the suction port.
For the Guardian canister, select the high, medium or low force for the motor. Then blow the dust out from under the furniture or use to fill an inflatable. Turn off the vacuum and replace the hose in the usual position and replace the filter when done.
If you are still unable to get the unit to blow out when connected to the exhaust port after attempting to clear the hose, separate the hose, wand and handle. Look down the hose for any object that might be creating a one-way valve. Remove the foreign object.Do the same with the other parts of the unit. Also replace the vacuum bag. If the bag is sufficiently full, the airflow will be reduced through the bag to the exhaust and cause the problem you describe.
The Electrolux Guardian Canister Vacuums are part of the Aerus line. The manuals for the vacuums are available here: http://www.aerusvacuums.com/support/manuals/index.cfm . The Guardian Ultra is in the current model section. The Guardian is listed in the Older Model drop-down menu.
I hope this helps.
(many canister vacuums have a blower mode when you connect the hose to the exhaust (after the bag) instead of the suction side of the unit.)
Aug 17, 2011 | Electrolux Guardian Bagged Canister Vacuum
How do I open the canister of the Aerus Electrolux Lux Guardian? I need to replace the retractable cord mechanism. Aerus won't help me.
This will not be difficult to open, however, inside may scare you.
Remove your hepa filter cartridge (if you have one)
turn the machine over.
Undo the 6-8 screws there and pull the bottom off.
you should see everything there. If you are careful, just remove the old rewinder, and replace with the new one.
Good luck.
Mark
Nov 08, 2010 | Electrolux Guardian Bagged Canister Vacuum
Vacum shuts down when suction starts
Try turning the knob on the top of the vac all the way to the right.
Jul 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
The light on the top of the vaccum stays light and
You have a Electrolux, not a Guardian though, right? The light you are talking about is the bag full indicator. I know your bag is not full, so, try this. The knob on the top of the cleaner is a fine adjustment designed to let the bag fill up in different conditions, (dirt types) . So...turn the dial down to setting 2. Try it again. Did it work? If so, this is your adjustment . No need to ever adjust it agin. It is NOT the suction control. If this did not fix ya (haha) then, your adjustment diaphragm is bad and you will have to break down and bring it to Aerus(Electrolux) for a repair. I hope this info was helpful, if so, please leave feedback, it helps my rating, Thanks, Rene(The Vacuum Doctor)
Nov 07, 2009 | Electrolux Guardian Bagged Canister Vacuum
My almost new miele Dog and Cat vac keeps telling me the bag is full when it's not (new bag, no clogs)and I have almost no suction. Any ideas?
Remove the hose and check the suction. It it is still bad check to see if the canister is closing on the bag. Most likely the hepa filter needs replaced. Here http://www.totalvac.com/mielevacuumcleanerfilters.htm
Aug 12, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Dust blowing out of hoover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618781&thid=617336
Dust blowing out of Hoover
Posted by Lunagus on May 23, 2008
When I start up my year old Electrolux Loopie Petlover vacuum a large amount of dust comes out of where the HEPA filter is - can you suggest reasons?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Upright 014T XL Pro 14 Upr Vac
In answer to your question, if the HEPA filter is leaking then you should replace it because it has lost it’s filtration – but my question is – is it on the Oreck, Hoover or Electrolux --- all three have HEPA filters and needs replacing and to make sure that the HEPS filter is installed correctly or other wise the filter will leak and if that happens then contact your local vac dealer in your neighborhood. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 23, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Electrolux Guardian Bagged Canister Vacuum Logo
450 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
