Question about Nintendo DS Lite Console
TOUCH SCREEN BROKE OFF OF CIRCUIT BOARD , tried to plug back in and the black clip came off board now there is nothing to hold it on with
    Sniper:
  • 69 Answers
Well, the previous solution and buying a new DS are the best way, or, you could try sodering it.
Posted on May 13, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Well the only way i think you could do is send it to Nintendo and ask them to fix it.
Posted on May 09, 2010
Bernina 180E Touch Screen Dark, machine light won't come on.
I don't know the circuit of this sewing machine but it gives me the impression the light and the board are in series with a fuse. If this is true the light will burn out and cause the screen to go black as well. If the fuse would go out the same thing would be true. Anyway, change the light first. If this doesn't work you will need to replace the fuse. If there are still problems it will need the mother board to be replaced. Tell me how this worked out.
Oct 24, 2014 | Bernina Artista 180
Tip
How to fix Sharp LCD model # LC-32SB23U flashing green power light and check and...
If the green power light keeps flashing on and off every second and tv will not power on unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim, leave the wiring pluged into this LED circuit board . With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Stand tv up and plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the side ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the bad lamp sockets, part # QSOCFA003WJZZ, by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it. If the power supply inverter circuit board is bad to replace it, unplug the (2) wire plugs at the top left side on the circuit board, take (3) screws marked with an arrow out, use a pair of sharp nose plyers and squeeze the plastic white tip holding the circuit board on the right side careful not to touch the high power circuit backlight plugs on the right side of the circuit board. Pull board straight out to unplug it. Replace with new board and tv should power on now.
on Sep 28, 2011 | Sharp Televison & Video
Nothing but black after replacing broken touch screen
Open the phone back up and unplug all the FLEX cables from the system board then plug all the FLEX cables back in, be sure that the flex cables are aligned correctly and full plugged in. Then try the phone again, I know there has been 4 times where I replaced an LCD and upon turning it on had nothing but black screen. Did what I said above and 3 times the LCD worked perfectly(must have been a FLEX cable not seated all the way) and the 4th time it was a bad LCD screen.
Aug 17, 2014 | HTC Desire Cell Phone
Baby oil in nintendo ds touch screen
Hi, you will most probably need to replace touch screen. Buy new 1 from ebay about 2 quid and a tri-wing screwdriver to take apart console. Youtube videos how to replace touch screen and follow video step by step. Not at all hard to do just make sure you don't break the black clip off the board that holds the ribbon cable for the touch screen, can be write fiddly. Magnifying glass will help and small tweezers.
Enjoy
Jul 21, 2012 | Nintendo DS Lite Console
My Nuvi 760 boots to the calibrate screen page. When I touch the dots as requested it wont respond. Then I am unable to get past this page. I have tried a hard reset, power on , power off, even removed and...
The best clue you gave is that you removed and replaced the battery. When you did that, I'm guessing that you accidentally disconnected one of the three ribbons that connect the touch screen to the circuit board. (It's very easy to do that.) Solution: disassemble the case again and inspect the ribbons. Each should be attached to the circuit board by a thin black spring clip. If you find one is not connected, use the plastic case-separator tool to carefully lift the black clip, slide the ribbon under it, and re-close the black clip to hold the ribbon in place. Here's a page with instructions and photos: http://www.portatronics.com/guide/GPS-Repair-Guide/garmin-nuvi-660-screen-replacement.html
Apr 18, 2011 | GPS
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Often freezes-solved by sliding phone up and down several times restarts itself 3 buttons on keypad no longer work
Hi,the problem you are experiencing is as a result of a faulty flex connector cable,it's bad hence it can send signals properly from the board to the screen which results to freezing of the phone.The solution is to replace the flex cable.
Here is a detailed solution to assist you in disassembling your phone and replacing the flex conn. cable;
1.Remove your back cover, battery, sim and memory card. Remove the four screws you see behind the phone.
2.Run your plastic tool e.g credit card,around the join of the battery compartment to release it.
3.You will see a connector ,it needs to be disconnected. Just flick the black latch up and pull the ribbon out.
4.Now remove the two screws on the upper edge of the phone. Both screws will be covered with red stickers.
5.Now move the slide down and remove the three screws you can see.
6.Lift the circuit board to the side slightly to reveal a ribbon attached to the underside. The connector attaches like a plug and socket. Just lever it away from the circuit board to unplug.
7.Pull the slider down to access four more screws. Remove these. Now run your fingernail or your plastic tool around the join of the front cover. This will release the clips which hold it in place. The cover will still be attached near the top of the phone so don't try and force it off .
8.The camera cover should now be loose. Remove the two screws you can see. You can now remove the front cover.
9.With the front cover removed ,the navigation pad and the part that holds this in place will come away with the cover
10.Pull the screen away from the rest of the phone. The c connectors needs to be released. For each, flick the black latch up where the ribbon enters and pull the ribbon out.
11. You now need to separate the LCD and touch screen. To do so you need to slide something flat and thin (the edge of a guitar plectrum would be best) between the LCD and touch screen. Try to follow the dotted line and try not to push your plastic tool too far under the touch screen or you'll get a sticky residue on the underside of it. Applying some heat with a hair dryer may help loosen the touch screen.
12.You should now have the LCD screen and touch screen separated. Reverse the whole procedure for reassembly.
Thanks and take care
Jun 21, 2010 | Samsung Tocco Ultra Cell Phone
I push my power switch and nothing happens. the
Jun 02, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Take apart MX3000
Please refrain from pressing too ******* the screen. The pressure responsive clear cover in front of the LCD screen can crack, resulting in a defective touch screen. If you truly wish to disassemble the unit, then there is a way. But please understand that this WILL void your warranty.
First, remove the battery cover on the back and unplug the battery pack, then remove the battery pack. Now, if your fingernail is strong enough, you can wedge it in between where the dark colored rear plastic plate and the light colored front plastic plate meet along the sides. Start in one spot, then slowly and gently work your way around the entire remote. If done properly, the two sections should begin to unsnap from each other. Once the back cover is unfastened, be cautious of the black wire connected to the ground shield on the inside of the back cover. Now you'll notice 3 seperate wire harnesses attached to the back plate that plug into the circuit board. Carefully unplug these harnesses. Don't worry if the small, black round device on one of the harnesses falls off the back plate. That is just the small speaker and can easily be pressed onto the back plate again. Once all the harnesses are unplugged, move the back cover around until it is out of your way, without pulling the ground shield wire loose. Now you should be able to see the green circuit board. The next step is to unfasten the wide, flat ribbon cable on the lower left side of the circuit board. Look closely where the ribbon cable is plugged into the white colored slot. On the sides of that slot are small black flanges. Carefully pull those flanges away from the slot to unlock the ribbon cable. You won't have to move the flanges very far. Now gently remove the ribbon cable from the slot and leave it there for the time being. Continuing, you'll need to remove the 4 small phillips head screws that secure the green circuit board to the front plate. You can possibly use a #1 phillips head screwdriver, but a #0 or smaller is preferred. Once all 4 screws are removed, you can begin to gently lift the circuit board away from the front plate. Be cautious while letting the ribbon cable slide through the slot in the circuit board. Once the circuit board is removed, you should be able to access the rear side of the lcd screen assembly. The screen assembly simply snaps onto the back side of the front cover plate via 4 small grey plastic snap studs. If your screen was already crooked in the remote, then one or more of these plastic snap studs may be broken. If so, then a few small drops of hot glue may help hold the screen in its correct position. Now, if the screen assembly was already in the correct spot, but the internal sections of the screen are what were misaligned, then it may be beyond self-repair.
This is as far as I can help with this. I'm sorry if I left out any steps, as I'm trying to conjure this from memory.
Good luck.
Apr 16, 2008 | Universal Remote Control MX-3000 LCD...
Battery charching input broke off of phone
Once the circuit board is damaged the phone is usually done for. The only thing i would suggest is to see if your service provider has a replacement phone or circuit board that a certified tech can replace/install. For future ref, opening the phone is a no-no and voids any warranty, the goes for super glue.
Feb 26, 2008 | Siemens SX56 Pocket PC
Nintendo DS Lite Console Logo
53 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
