How do I change frequencies on my Audio Technia ATW-T202 wireless microphone?
  • 4,234 Answers
These units are not changeable in the field. These are set at the factory.
Dan
Posted on Mar 27, 2008
SOURCE:
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Nov 10, 2014 | Audio Technica Audio-Technica ATW-T202...
I have problem with channel on Audio Technica wireless microfon How can I change the channel because the same things wireless channel digital television and she considers the work of the microphone. Type...
I don't think is possible. But its entirely my point of view,as i feel technically its not possible.
Try checking your user manual provided for microphone. That may offer you better guidance.
Oct 10, 2017 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
Replacement lavalier transmitters
The ATW-R12 is not made any more. We here at Pro Line Music are Audiotechnica Dealers. I would need to know what frequences the transmitters are to see if there is another unit that can match thoes frequences. call 215-736-8055
Jan 02, 2010 | Audio Technica ATW-R12 DIVERSITY RECEIVER...
Changing frequencies on wirleless microphone
No, the ATW-R200 series are fixed-frequency units.
Short of soldering new crystals in, you're stuck with the frequency you've got.
Sep 21, 2009 | Audio Technica Audio-Technica 200 Series...
How do I fix the on/off switch for and ATW-T202?
Had the same problem - faulty switch. The switch was labeled ALPS so did some searching and found a replacement switch at Mouser Electronics. P/N SSSS928200. Switch is $.64 + shipping. So I ordered 3.
Best way to replace it is destroy the old switch in place careful not to damage the solder lands on the PCboard. Then unsolder each pin using minimum heat to not damage the PC board. Insert new switch an resolder. Note carefully the routing from the pins so if you do damage a land a short piece of wire to its destination will replace the damaged routing.
May 05, 2009 | MCM Audio-Technica ATW-T202 Microphone
Two diffrent units with two diffrent frequincys . i wantto change
I hate to be the bearer of bad news but those units are fixed frequencies and cannot be changed. You either have to find a mic that matches your receiver or vice-versa. The freeway 200 series comes in 3 freqs. two of witch you have with the addition of 170.245. Maybe you can find someone who has a damaged mic but still has the receiver with the freq. that you need for your mic.
Apr 11, 2009 | Audio Technica Audio-Technica ATW-T202...
Wireless noise
the unit I'm using is old and is on a 200mhz frequency and it uses Vhf, so I have to buy a new unit.....nothing can be done to fix the problem....
Jan 21, 2009 | Audio Technica Audio-Technica 200 Series...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
60 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
