Question about Weather King 12AJA4201AH Air Conditioner
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards the back end so the electronic components are not in danger. I was told if it started dripping that I needed to be concerned. I'm a kind of DIY person cause I like to save money so any advice is much appreaciated. What should I check? What needs to be cleaned or replaced?
    Guru:
  • 60 Answers
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
Posted on May 08, 2010
I have a ruud silhouette furnace. it's been here in the attic since the house was built in 2001. There is a metal pan around the base of the furnace and it keep filling with water.I see where the wate
The water is condensation from the evaporator coils and is normal. There should be a drain pipe or hose from the pan either to the outside of the home or into the wastewater drain. It is also normal for dirt to accumulate on the evaporator coils and some of it ends up in the pan and clogs the drain. Cleaning the coils and flushing out the drain is something that should be done at least yearly.
Sep 12, 2014 | Heating & Cooling
Good day. I have an older Rheem electric furnace inside my house. I just opened the front to change the filter and found water at the base of the furnace. It had got part of the filter wet. The furnace...
Check your A/C condensate pan; it has a drain and drain line. Make sure the drain isn't obstructed and the drain line is clear. As far as the electric furnace, if you allow it to dry out thoroughly chances are nothing detrimental will have happened to it; especially if it's an older unit without the sensitive electronic boards on it.
Jun 27, 2011 | Heating & Cooling
There is water in the pan in the attic of the York 80 unit. The drain line that goes out from the unit, outside appears to be clear. What next?
The condesate drain is clogged, most of the time they clog at the trap close to the furnace.You need to clear the clog and clean the drain line and drip pan if you can get to it.
Jun 19, 2011 | Heating & Cooling
I have a Carrier central air unit in the attic. There is water dripping through the ceiling. There is a problem with the internal drain pan, as the unit drips a LOT of water into the emergency pan. There...
The internal catch pan is very time consuming to replace, especially since it is located in the attic. But before you try that, have you checked to see if the drain line is clogged with algae and that it has the one inch to one foot drop you need for proper drainage? Has you house settled throwing the slope off?
If you live in the South algae growth can clog you drain line. I would disconnect the drain line (have a bucket handy) and see if it is clogged. If you have algai growth then you need to treat with bleach to kill it off. You might also want to run a drain snake through the rest of the line to make sure that it is clear.
Jun 05, 2011 | Carrier 38CKC060 Air Conditioner
I have a Goodman A/C unit model number AWUF36106BA and serial number 1010684384. It keeps shutting off on us and we have had a repair man come out and said the problem we had is the emergency shut off...
If the drip pan switch is shutting the unit down , this means you have a condensate drain issue. Be careful about wiring around any safety switch, especially if the furnace is in the attic or on a second floor. You could have water dripping on the ceiling. The drip pan switch is a safety switch. The best thing to do would be to inspect the furnace. The pan is underneath it. Look inside the pan if you can. If it is full of water, use a shop vac and vac the water out of the pan. If there is no water, you can locate the safety switch, take the two wires loose from it and just wire them together. Caution: This will be wiring around the condensate safety switch that could cause water to leak on the ceiling or floor depending where the furnace is. Don't go too long without getting someone out to clean the condensate drain out.
May 01, 2011 | Goodman CKL36AR36 Air Conditioner
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
AC unit seems to be working normally but not cooling house
If you are referring to the secondary pan there could be a problem with your drain line.i would find the drain at the exterior of your home and **** it out with a wet vac..most A.H.Us have float switches or moisture sensors.They will shut down the unit if the drain clogs.
Jun 21, 2009 | Weather King 10AJA3601AH Air Conditioner
Weather King 12AJA4201AH Air Conditioner Logo
485 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
