No sound from TV; volume bar operational, but no sound at all. I suspect my husband pushed some bizarre button on tv or cable remote.
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Maybe check your menue to see if the speakers got turnd off or maybe on mute
Posted on May 10, 2010
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
No sound on tv but volume is up
If you have an older style television and you have cable-then you have 2 remotes-somehow,the tv part went on mute but when you check your sound with the cable remote-it shows high level of bars which makes for confusion!Get out the old tv remote &select your menu then sound &take it off mute----You'll probably see see--sound off! Turn sound on and adjust your sound bars with same tv remote till just a bit more than 1/2 way up.That way you will not have to use cable remote to make it louder-much.In case,you forgot where you put your tv remote& only have cable one--think you can still get it off mute--byshutting down the cable part(which you have probably done several Xs by accident)---and then with cable light not coming on-right- only the tv light =try & adjust with cable remote by pressing mute button-should see MUTE go off!Then bring your cable button back into play and should be all set to go.If that does'nt work and your tv is still a tube tv might need a new part.But hope it was the simple problem.& that I managed to help you.Bye.
Aug 17, 2012 | Televison & Video
The volume up button on the remote and the tv are not working at all and the volume down button works but it does not turn the volume down instead it cycles through what seems to be different modes of...
SEEMS TO BE STUCK IN MENU MODE ,TRY PUSHING THE MENU KEY ON YOUR REMOTE AND THEN PUSH IT AGAIN,,HOPE THIS HELPS.YOU CAN ALSO HIT THE MENU BUTTON ON THE TV ITS ON THE LEFTHAND LAST BUTTON....
Jul 15, 2011 | Samsung CXD1342 13 in. Combo
My TV lost image, but has sound. I`m out of warranty, what should I do? (PS: I`m a woman, so please explain it nice and slow :) )
Please read all before starting!
I'm a woman too. The first thing you have to do when your tv no longer has a picture is to determine whether or not the television needs to be repaired. The way to determine this is to perform some troubleshooting. The easiest thing to do is to turn the television on and turn the volume up and down on the television remote while looking at the screen. Do you see the volume bar going up and down as usual? Or is the volume of the tv set going up and down, and you can hear the volume increasing and decreasing but you cannot see any volume bar as usual? Also you can press the menu or display or info button (whichever of these your television remote has) and see if any writing whatsoever appears on the screen. I am asking you to use your television remote at this point, which is the one that came in the box with your television (not your converter box or cable box or satellite tv receiver or surround sound remote--I am speaking of your actual television remote).
I do understand that some people don't use their television remotes and disregard them putting them in a drawer or somewhere else and can't get to them. So if that's the case you can use the buttons on your television itself. There should be a volume up and a volume down button but DON'T push the channel buttons or the source/input button.
Ok if you see the volume bar going up and down or some menu or display information that is good. That means the television is ok (most likely). Then the problem would be with the stuff that you've got connected to your television or with the stuff you're connecting it with. Just try connecting something else to your television with the same cables, and then if there is no picture with new stuff connected try connecting the new stuff with a new cable. Remember that when you are connecting stuff to a television you have to select a corresponding input/source on the television in order to view it. The back of the television is labeled. If you plug something into video 2 or input 1 then you have to select that on your source/input button on your tv remote or tv panel.
If you isolate your problem to your cable box or satellite receiver or your cable service then you can contact the cable company or satellite company directly. Your box may need to be rebooted or replaced by them. It might also be a setting in the box. If you can do some of the troubleshooting and get back to me I can help you further when something has been ruled out or a problem has been isolated.
Apr 13, 2011 | Televison & Video
I have a problem with my Panasonic CT-27SX12 27"
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
Nov 18, 2010 | Panasonic CT-27SX12 27" TV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
DTV remote code
KZXten,
Don't know if this will help but I have Comcast as my cable TV provider and am using a Motorola DCT-6200 STB and the remote Comcast provides with the STB. To get my Panasonic TV/VCR combo (PVQ-2510A) to work with the Comcast remote I had to do the following:
1) Do the remote code search in AUX mode (or VCR or DVD mode if your remote has that button instead) using the instructions for searching ing remote codes. I had to toggle back and forth between AUX and POWER on the remote until the TV turned off. I saved that code on the remote, but it only controlled the power on the TV, not the volume control.
2) Next I did the remote code search using the TV button on the remote and toggled between the TV button and the volume control until the volume +/- bar appeared on the screen. I saved that code too.
I use the AUX button to turn the TV on and off. Once the TV is on the volume control on the remote operates the TV volume normally. I still need to toggle between CABLE and AUX depending on which device I'm controlling, the cable Set Top Box (STB) or the TV. You may have to experiment some to get it to work correctly.
Here's a link to the remotes Comcast is providing in my area.
http://www.comcast.com/corporate/customers/customer_support/remotes.html
Dec 23, 2007 | Panasonic PVQ-2510 25 in. Combo
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
