Question about Whirlpool Washing Machines
I have a AWO 9750 and the pump sounds like it's eather vibrating or the bearing is going out. It goes though all the cycles most of the time but every once in awhile it stops at 17 mins. and I get a FO flash. I restart it on the same program or unplug it and it finishes the wash program. Is this a problem that I can fix myself with cleaning? Tack
  • 141 Answers
I hope so you are having the problem with the capacitor of the unit or the main board capacitor is open kindly check it and replace the spare
Posted on May 08, 2010
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Some time ago I got new tires put on my 2010 dodge ram 1500 and after that the truck kind of vibrated I figured just the tread off the tire so I ignored the vibrating. Now I currently have abs. Esp....
If it wasn't vibrating before the new tires and was fine then it has to be the tires maybe just one, or sounds like they didn't torque the lug nuts to the right specs, putting the rim out of alignment, but if they took the wheels off to rebalance then that rules that out. I would go to a different tire shop and have them check it out....Also on a long shot they bent something in the suspension when changing the tires, possible fell off the jack or something similar. Good luck
Feb 19, 2015 | Dodge Cars & Trucks
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Ge super capacity plus washer
It sounds like your bearings are are whacked, if you have vertical
movement in the drum the bearings will need replacing , not a simple job as seals also need replacing
Dec 20, 2013 | Washing Machines
Renault Traffic 1998- Front passenger side tyre had a vibrating sound thats comes n goes when moving in straight line. It sounds like the brake is slightly on. The vibration stops when cornering.
If your brake is not releasing you could have a stuck caliper. What I would try first though is the brake hose going to the caliper. As the hose gets older the hose walls tend to break down and weaken so they collapse when the pressure releases not allowing the fluid to go back.
Mar 07, 2012 | Cars & Trucks
I have a 5.5kg Simpson Ezi Sensor SWT552 Washing Machine. The lid locked light keeps flashing and the machine keeps beeping during the spin cycle - even though the lid it down properly. Could you please...
yes the safty door latch switch is eather loose or going bad. somewhere on your door there is a small sensor or switch that tells the washer the door is closed and its ok to spin, these washers put out alot of force when spinning and thats why the sensor is there it would be dangerous without them. when the washer goes in spin cycle there is more vibration than any other cycle. and thats whats making the sensor or switch wiggle and its getting an intermedate signal. it probily needs replaced these can commonly go bad due to wear buy slamming the door on the washer.. i hope this helps
Sep 09, 2011 | Washing Machines
Leaking from the seams of the washer when I turn it on
sound like you have a hole in the hose between the pump and tub if not you eather have a hole in the tub or the seal and bearing where the gear case goes through is worn out realy by ir this is the case you would have had some water leaking for a while though.
Jan 16, 2009 | Maytag Performa PAV2200
Wheel Bearing
Yes, it's time for wheel bearing replacement. It seems a little premature to me though.
Jul 02, 2008 | 2006 Chevrolet Malibu
CLOTHES STILL SOAKED AFTER SPIN CYCLE
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it http://maytagwasherrepair.googlepages.com/index.html
Apr 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
81 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
