Question about Sharp AL-1641CS Laser Digital Copier
Sharp AR-M450 can't scan to e-mail
I am having an issue with Scan to Email functionality on the Sharp AR-M450N copier/scanner/fax. I am receiving error code CE-00 when trying to scan to email. I can ping it over the network and can still send print jobs to it via network, but it will not scan and send to email via network without getting the error code CE-00. I have setup the smtp address in the network setup on the copier.
  • Anonymous Mar 19, 2014
    I can setup my scan to email for my Lexmark 901 using my roadrunner email
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Posted on Apr 20, 2009
You should use a USB connection from your pc
Posted on Apr 18, 2008
I would verify that the SMTP and LDAP servers are correct.
Posted on Nov 21, 2008
Controls / CONTROLLER FAN MOTOR
Yes its the developer motor. mite need to be replaced I would check the developer unit first, also mite replace the developer
Aug 28, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
My sharp MX-M450 turns on but there is no display, why?
sometimes if there is a fax board on the back and the power switch is off on that it wont light up the display. either that or something is wrong with the display itself. sometimes those ribbon cables have to be replaced that power it.
Copier Collin Houston TX Copier and Imaging Expert
Jun 29, 2014 | Sharp AR-M450N Copier
Error code U6-02
You have a large capacity double tray, the code is for the lift up motor in the right hand tray (that lifts the paper stack to the rollers) pull out the tray and see if there is paper wadded between the tray and the back wall of the machine blocking the motor boss from meshing with the tray.
Clear the motor error code with SIM 15 in the service area of the machine (from copy mode, # * C * to access)
If the code comes back your lift motor is worn out and needs to be replaced
Apr 20, 2014 | Sharp Mx-m450n Mfp Multifunction Booklet...
Service manual manuals
http://www.smpcshop.com/Sharp-AR-M280N-Sharp-AR-M280U-Sharp-AR-M350-Sharp-AR-M450-U-N-Service-Manual.html
Nov 23, 2013 | Sharp AR-M450N Black & White Copier
L6-10
sorry you must change laser unit
May 26, 2010 | Sharp AR-M450N Copier
Call for service h5-01 on sharp AR-M450
The machine is indicating there is a paper jam in the fuser that has not been cleared. Paper will fold in the fuser tight and may be difficult to see.
Mar 09, 2010 | Sharp AR-M450N Copier
Sharp AR-M350/M450 scan to desktop
Network scanner tool (or NST) comes bundled with the Sharpdesk application. It can be loaded as a standalone but it is bundled software. If you have dealer access to Sharp's website you could download the software from there.
If this is a client of yours you should be selling them another copy of the software as it is no fault of your own that they misplaced the CD plus its extra revenue.
I would love to help you otherwise, but this is copyrighted software.
Mar 23, 2009 | Sharp AR-M350U Copier
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Sharp AL-1641CS Laser Digital Copier Logo
3,073 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
