Question about Whirlpool Duet GHW9150P Front Load Washer
The washer won't start. It clicks a few times, then starts beeping. The display says "dl", then "F" I've checked the door, it's shutting.
  • 3 more comments
  • Sally Goldberg May 08, 2010
    I'd like to fix the door myself if it's not too difficult. What does it involve?
    I can't tell if you got my reply.
    How do I fix the door?
    GHW9150PW0
    CSR3616503
    199 - 082WT/GY
    Why I'm at it do you think I could reverse the door hinge myself? It opens the wrong way.
    Yes. thanks a lot.
    President:
  • 949 Answers
Sorry you are having trouble, this is usually a great machine.
The F indicates there was a failure, the dl says it is the door lock.
Since you have made sure the door is closing properly the most likely suspect that could cause this is a failure of the door latch assembly itself. Let me know if you would like instructions on repairing it yourself.
Posted on May 08, 2010
  • 2 more comments
  • Philip May 08, 2010
    I did the reply just now, I will put some information together and get it to you in just a couple minutes.
    Can I get your complete model number off the tag just inside the door please? This will aid when putting the instructions together for you.
    Thanks!
    The part number you are going to need is 8181700.
    The numbers I refer to in these instructions correspond to the diagrams below. Let me know if you have questions.
    - Unplug the power cord from the washer
    - There will be 3 screws (8) coming around the door latch visible on the right side with the door open. Remove these screws, they are T20 Torx I believe.
    - Remove spring ring (14) it is visible under the lip of the front bellows (gray boot/seal) the spring ring will pull off
    - Reach in to the right and the wires will be long enough to disconnect, do not disconnect until you have the new switch there so you can be sure to put the wires on the same place.
    - put the switch back in place and then put the 3 screws in. Put the bellows back on then the spring, plug in and you are good to go
    Oh the latch assembly is part 7 in the diagram.
    The door to the washer is not reversible, only the dryer door can be reversed, sorry.
Maytag Brovo 300 seies washer display says dl and will not wash
The error code "dl" is for door lock. From what I've read, it may mean you need to replace the latch assembly.
Sep 07, 2014 | Maytag Bravos MTW6600T Top Load Washer
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Elite HE4t Washer won't start
Hello Ameliafaith,
E-Z job...
If you take your model on line... to SEARS
(I don't ordinarily recommend)... BECAUSE THEY COULD ACTUALLY ... decode your ABREVIATED part number...
110. blah blah blah... (45986??)
The other sites actually have helpful VIDEOS...
But I already wasted enough time on this floundering with your
erroneous number (wrong no.)...
You will see these parts are reasonably priced and
very popular.. meaning they INDEED FAIL ... alot.
Go here:
Washer Door Lock Assembly Part Number 8181700 Sears PartsDirect
Carnac the Magnificent
Jun 07, 2017 | Kenmore Elite 45986 Front Load Washer
Dl and F flash when I'm trying to start the cycle...
sorry for the delay in getting back to you. you have a bad door latch mechanism on your washer that needs to be replaced.
Dec 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
Pushed start button to begin cycle. washer started beeping and display was flashing F and the DL repeatedly. unplugged washer for a long time, opend and closed door. also checked water pump screen in the...
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Apr 25, 2011 | Washing Machines
Washer will not start, it beeps and say's dL / F
Door Lock Error---(F/DL)
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
• Door Lock/Switch Assembly Failure
This will essentially be the result of a failed door locking mechanism(wax motor failure). The necessary actions are to replace the entire door locking assembly. Click here to access the repair manual for your unit. This universal duet manual will guide you through the necessary testing procedure and component accessing, as well. Replacing the door locking mechanism will correct this issue.
Aug 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door won't latch and dL and F come up
your dl (door latch) is broken replace it you can order it from searsparts.com
Apr 26, 2009 | Kenmore Washing Machines
Start and after few minutes show "dl" f
easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
