Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
WATER PUMP WHERE CAN I BUY A NEW WATER PUMP FOR MY BISSELL 7920
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
eyhj
Posted on Sep 30, 2010
Bissell proheat pet. no water to floor cleaning mode; water works to tools. is this a pump problem?
Most likely filter clog. Check your User's Guide for specific locations of the two small filters. The Guide recommends cleaning after each use. Bissell Consumer Care is 1-800-237-7691
Jul 05, 2014 | Bissell 7920 ProHeat Pro-Tech Upright...
New replacement pump on Bissell ProHeat Protech not working
Not sure if I have the same model but this is what I found on mine this morning - wire to switch in the handle came off. Un-plug power cord. Unscrew top two screws on upright handle and remove the front cover above the trigger. see if wires are connected. top connector is not used - if you do solution will spray all the time. Good luck!
Jul 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Can't get the water to spray out when I turn it on?
When it doesn't dispense water or solution that means that the pump belt needs to be replaced. You can get a replacement and view the manual here:
Bissell 7920 Pump Belt and Manual
Dec 09, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
My unit will not dispurse water nor **** it up I have cleaned all the pieces I can see of any debris but still nothing. any suggestions?
Usually when it dosen't dispense water that means that the pump belt is worn or stretched. You can get a replacement and view the manual here:
Nov 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Water and soap coming out wheel area
heatman101
fddf
Apr 10, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
No water or solution will come out of my Bissell when trying to clean the carpet
Make sure there is water in the tank and that the autoload assy is not blocked. Is the pump belt still connected? There may be a blockage at the heater or finally a new pump may be needed.
Nov 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
73 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
