Question about ASUS P5RD1-VM Motherboard
Does not boot
P5RD1-V (775 socket) board had an 800 FSB 2.8 gig Intel processor on the board previous --but the machine quit - -and --the processor was O.K. and it was used on a different board--but , on the original board (P5RD1-V)
I put an old 1.6 processor , which did work previous, --yet the machine, then, would not boot , except , to momentarily , start the power supply fan, and heat sink fan --then stop --I changed the location of the fan connections,
or disconnected completely, --tried various power supplys --which worked on other machines, yet not on the P5RD1-V , - -and also , there was tried,
AGP video cards and also PCI cards - - yet , there seemed to be no voltage to run the PCI card fan --(slot #1 PCI) - -the monitor does not lite
when the momentary boot starts--but --when continous push of the 'reset button' - -and the start button--the fans continue to run --yet no monitor lites.
A best guess - -the Bios file is either corrupted, or the main board has a
short or open cirucuit. - -The memory on the board was also changed, to
eliminate that possibility. There is a possibility, that a file came from the net which corrupted the Bios file . At times--upgrade files don't always provide what the suggestion might be . - -Thank you for your concern .
    President:
  • 2,351 Answers
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
Posted on May 09, 2010
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
Downgrade intel 41 cn to support processor intel p 4 541 3.2ghz/1m/800/04a l723b 071
You need the motherboard user guide for clock settings etc but first ensure that the socket set (number and distribution of pins) on the new CPU matches that on your board. You should find a user guide on the manufacturers website, follow links for support and downloads.
Here's the page for your CPU on the intel website:-
http://ark.intel.com/products/27468/Intel-Pentium-4-Processor-541-supporting-HT-Technology-%281M-Cache-3_20-GHz-800-MHz-FSB%29
According to this, *********** board needs to have a PLGA775 CPU socket.
Assuming so, its a case of setting the clock jumpers to match the processor speed.
Feb 22, 2012 | Computers & Internet
What processor can i use with 446476-001 system board
The HP 446476-001 laptop motherboard, or also stated as HP motherboard used for the HP Pavilion dv6000 series of Notebook PC's;
A) Has an Intel 965PM motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core_2_mobile_chipset
Has a;
B) Socket P processor socket, for Intel processors
http://en.wikipedia.org/wiki/Socket_P
Using this information you know;
1) That the Intel PM965 motherboard chipset supports
Intel Core 2 Duo processors,
with either a 533MegaHertz Front Side Bus, or a 667MHz FSB, or an 800MHz FSB.
[Note*
The motherboard chipset is the Northbridge, and Southbridge chip, for YOUR motherboard technology.
(Does not apply to motherboards that support the Intel Core i3, Core i5, Core i7, and Core i9 processors)
The Northbridge part number is Intel 82965PM.
You won't see this part number on a chipset, because the Northbridge chip is under a small finned heatsink.
The Southbridge chip is an Intel ICH8-M
Part number is 82801HM. This you should see on a chipset ]
2) That the processor socket is a Socket P.
So you need an Intel Core2 Duo processor, with either a 533MHz, or 667MHz, or 800MHz FSB, and fits in a Socket P processor socket.
For additional questions please post in a Comment.
(You may, or may not need a BIOS update )
Regards,
joecoolvette
Feb 18, 2012 | Computers & Internet
I have an HP Pavilion a335w computer. It's running a P4 2.5GHz processor (Northwood A80532) 512 L2 with a 100MHz FSB. It has a TriGem Glendale motherboard, PGA478 socket, and it's maxed at 1MB RAM. How...
I have a Compaq that came with this board and a celeron 1.8 or 2.0 I believe. The fastest P4 that will run is a Intel Northwood 2.8 Ghtz 400 FSB nothing ELSE! Northwood 2.8 is the fastest 400 FSB, the boards chipset won't run anything faster than 400 FSB. Mine is running, Win 7 the Northwood P4 2.8 with 2 gigs ram, 160 gig HD and a 256 video card for over 5 years (minus win 7, had XP before with no issues. Good for light gaming, web surfing and MS office! Add a Zotac 512 MB PCI or Sparkle Video card and you can handle most more medium gaiming out today!
Dec 18, 2010 | HP Pavilion a335w (Refurbished...
Bios update for t5226... intel update will not work.. some people say it is locked by emachines. i am trying to put an e8400 in it, but i don't think that the processor is supported by the older bios...
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
Feb 18, 2010 | E-Machines T5226 PC Desktop
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
Will an Intel E7400 processor work with an MSI P965 Neo F V2?
Your processor "Intel E7400" is listed as a socket 775 Intell core 2 duo processor. Your motherboard "MSI P965 Neo F V2" is listed as an Intell board using a socket 775 processor socket. The front side buss (or fsb) speed capabilities of the mother board, and the buss speed of the processor are compatible They should play nice with each other.
Good Luck!
Jul 27, 2009 | Intel Computers & Internet
I have an asus p48vx-x motherboard
you may check
1) your Intel pentium 4 3.2 GHZ cpu socket 478 processor #sl7nb what's FSB?( see on the chip surface, if 533 FSB can use but 800FSB could not match your motherboard if which is not support 800 FSB. that's why no display.
2) check RAM stick speed, try to increase a level, for example 266 to 333.
is this helpful please feedback thanks
Feb 12, 2009 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Support
ecs_buttom_03.gif LGA775 socket for latest Intel® Core™ 2 Duo / Pentium® Dual Core/ Pentium® D / Pentium® 4 / Celeron 4xx series/ Celeron® D processor ecs_buttom_03.gif FSB 1066/800/533 MHz
The above information was taken from their website.
Jul 06, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
ASUS P5RD1-VM Motherboard Logo
158 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
