Question about Bosch Nexxt 100 Series WFMC1001UC Front Load Washer
My bosch nexxt 100 series washer won't start. yes, it's plugged in, none of the settings will do anything. any suggestions?
  • 1462 Answers
SOURCE: will not spin or drain
no drain then no spin
check filter and check for foreign objects jamming the pump impellor - usually bits of bra wire
Posted on Aug 05, 2008
SOURCE: Bosch Nexxt 100 Series washer
Bosch Nexxt series 100 place clothes in machine start add detergent as always machine begins to add water for about 30 seconds then stops , sometimes stops and sounds like it is trying to drain sometimes just stops and won't unlock door even if you turn machine off. Sometimes if you switch from hot to cold washer will work just fine for a couple of days then back to just stopping.
Posted on Sep 23, 2008
farr64
  • 121 Answers
SOURCE: bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Posted on Sep 14, 2009
barkencoa
  • 3463 Answers
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Posted on Jan 11, 2010
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
  • 3463 Answers
SOURCE: bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Posted on Mar 15, 2010
Bosch Nexxt 100 washer will not fill with water.
Does the problem occur on both hot and cold washes. If not then check the inlet solenoid . If yes than check the board.
Jan 25, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer wont spin belt is on pump is free of debris
Possible that the main motor is jammed or does not get power from the program controller unit. It is important that you measure the voltage at the motor when the program is set to start after the inlet valve fills water. If there is no voltage then the program controller unit is faulty.
Click this link for support : washing machine tips
Jun 25, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a 2009 bosch 100 series washer that won't wash or spin, but will drain?
I realize that this post really old but I wanted this to be available for the next guy. I bought Bosch part number 154740 which are brushes that worked for me. They will tell you it wont work but it did for my Bosch (wfmc1001uc/09) washing machine.
Mar 06, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
How I can clean fliter for washer machine bosch nexxt 100 series
just unscrew the filter plug located usually front bottom of machine.
Dec 13, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
Jun 28, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch 100 series will not drain
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Thankyou.
Jan 11, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My dryer won't start. None of the buttons will light up when pushed. It is a Bosch Nexxt 100 series. It is plugged in and adjacent appliances (washer) work.
Remove the top panel and check for any wires that may have popped off from there connections!!
Do not forget to unplug the dryer from the power source for your safety!!
Oct 23, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Logo
108 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
