Question about IBM USB Portable Diskette Drive (05K9276) External Floppy Drive
Download of the driver
Download of a new driver
After installation of the Portable Diskette drive it asked to formate the disk which are stored all data files already
Thank
Posted on Aug 10, 2010
Ibm portable disk with iMAC
You should be able to use it, just plug it in then open up disk utility which can be found in applications and then utilities. Once open you can format whatever way you require.
Jan 27, 2012 | IBM USB Portable Diskette Drive (05K9276)...
How would i go about formatting a computer?
How to Format a Computer
Want to know how to format a computer hard drive?Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
How to Format Computer Quick Links:
How to Format a Computer with Windows XP
How to Format a Computer with Windows 95, 98, & ME
Wipe All Data Before Formatting
Reinstall Windows XP
Reinstall Windows 95, 98, & ME
Create a Startup Disk
The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.
Your computer should automatically boot from the CD to the Windows Setup Main Menu.
At the Welcome to Setup page, press ENTER.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.
How to Format a Computer with Windows 95, 98, or ME
To reinstall Windows, you will need a Startup Diskette and a Windows Installation CD.
Download the Startup Diskette Creator
Note: We recommend using the Startup Diskette available on this page. Other Windows Startup Diskettes may not work with the following steps.
Once you have your Startup Diskette, insert it into the floppy drive and restart your computer.
Select option #1 - Start the computer with CD-ROM support.
After a minute or so, you will see "A:>_".
Type "fdisk" and press Enter.
If asked to enable large disk support, select Y for Yes. (Note: Some versions of Windows 95 may not be compatible with large disk support. Select N here if it does not support the FAT32 file system.)
Select Option #1 - Create DOS partition or Logical DOS Drive.
Select Option #1 - Create Primary DOS Partition.
The drive integrity will be verified.
Unless you are planning to make multiple partitions, select Y when asked if you want to use the maximum available size for the partition and to make the partition active.
The drive integrity will be verified again.
When completed press the Esc key to exit fdisk.
Without removing the floppy disk, press the reset button on the computer or press the keys Ctrl then Alt then Delete and release them together. This will restart the computer.
Again, select the option to Start the computer with CD-ROM support.
When you see A:>, directly above it is a message about your CD-ROM drive. It will tell you the letter assigned to your CD-ROM drive, take note of it.
At the A:>, type "format C:" and press Enter.
Press the Y key then the enter key when asked if you want to proceed with the format.
The format will probably take some time, so be patient.
You will be asked to choose a Volume Label, which is a name for your hard drive. It has no effect on the operation of your computer, you may choose any name you like.
How to Reinstall Windows XP
To reinstall Windows XP or 2000, imply insert Windows CD and restart your computer.
If your hard drive has not been formatted, Windows XP will walk you through the formatting process described above
Your computer will automatically boot from the CD and begin the installation process
How to Reinstall Windows 95, 98, or ME
After formatting your hard drive as described above, insert the Startup Diskette into the floppy drive and restart your computer.
Place the Windows Install CD into the CD-ROM drive.
Type "E:" (where E is the letter assigned to the CD-ROM drive) and press the Enter key.
Type "dir" and press Enter. You will see something like the following:
Volume in drive E is 020409_1121
Direct
Dec 15, 2011 | ASUS Computers & Internet
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
I have a Teac USB portable diskette drive, N533. Until recently, it has worked okay. However, it has started not opening any diskette I put in and instead a message appears that the disk needs to be...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 28, 2011 | Teac IBM USB Portable Diskette Floppy...
Issue in installing OS
OK. Well the error appears because the installation process doesn't recognize your hard drive device. And from the error I suppose it is a SATA HDD. You have two options: 1. Enter Bios, look for hard drive settings and change the mode from AHCI to Compatibility 2. Put the Motherboard CD into the optical device, insert a diskette, boot from the CD and select from the menu the option that is says something like "Sata drivers" or something like this. Restart the computer, insert the Windows XP CD and press F6 when it ask you if you want to install a new hard drive. Select to install the drivers from the diskette and continue the installation as normal
If you need further assistance, just leave a comment.
Apr 07, 2010 | Microsoft Windows XP Professional
I have a USB portable diskette external floppy drive. It is new. It is supposed to work by simply plugging the in teh usb. When I try to use it, it always tells me to format the disk. i of course, do not...
Try different and empty disk, then format it, when you can open it after you format it, then your first disk is damaged.
If still persist, then clean the drive using floppy drive cleaner, it should work.
Oct 17, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
IBM USB Portable Diskette Drive (05K9276) External Floppy Drive Logo
1,381 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
