Question about Dryers
I need to know the part number for the door switch? And if there is any interchangable switches that will also work? The dryer is a whirlepool model number ler8648lgo.
    President:
  • 1,554 Answers
The door switch for your Whirlpool LER8648LG0 dryer is part number 3406107.
Posted on May 08, 2010
Testimonial: "Thank you for your answer, it will work great. Now I just have to find one and buy it!"
Michael Pryor I got a dryer model number.WED7500VW, is not turning on door switch onewire Was burn....
The door switch activates when the dryer door is closed. On most dryers, the door switch makes an audible clicking sound when it activates. To determine if the door switch is working, try starting your dryer and then listen for the "click." If the door switch makes a clicking sound, it is probably not defective. If you don't hear a click, use a multimeter to use the door switch for continuity. If the switch does not have continuity, replace it.
Aug 30, 2016 | Dryers
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Dryer wont start
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a video to show you how to do the repair. If you would post your dryer make and model number, I will be able to point you to the part you will need. richroth_35.gif
Happy Holidays
Dec 15, 2010 | Dryers
My kenmore dryer 80 series electric wont turn on
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Here is a video to walk you thru the repair. If you will post the model number of your machine, I will be able to point you the part you need.
Dec 08, 2010 | Kenmore Dryers
Dryer will not turn on. I jiggled the prong that goes into the door switch and it worked one more time. Now it will not work.
The door switch is a normal part that fails...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 29, 2010 | Whirlpool LER5636P Electric Dryer
I have power to the dryer and it allows me to choose drying cycles but when i push the knob in to start the dryer it has an error code of "DO" and will not let the dryer start. I have tried to unplug the...
DO stands for Door Open.
Check on the inside of the door and insure that the plastic tab-like, finger-like actuator that fits into the slot on the dryer is still there and not broken.
This tab is what pushes in the door switch on the dryer and let's the dryer know it's safe to start. If it is there, you could have a bad door switch or control board.
I'd suspect the door switch first.
You can take a flat-head screwdriver and stick it into the slot at the door switch while pushing start to see if the dryer runs. If it does, you're door switch is ok. If not, we need to replace the door switch.
I can help you further by getting you part numbers and part-ordering information, but I'll need the make and full model number.
Try those tests and get back to me?
Best, G
Aug 04, 2010 | Maytag Neptune MDG9700A Gas Dryer
DRYER DOES NOT DO ANYTHING
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryer will not work
If it is whirlpool--Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks and clicks when you close the door then you have a bad thermal fuse. The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 18, 2009 | Whirlpool Dryers
Dryer will not start
Door switch part number 3406107
May 17, 2009 | Whirlpool LEQ9858L Electric Dryer
Washer door
The washer door is not switchable, but you will need a kit to switch the dryer door. talk to your sears rep for the kit number
Feb 02, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
