Question about Kirby G4 Bagged Upright Vacuum
Kirby Suction and Blower Connector
I broke the suction and blower connector (Generation 4) and was wondering if I can disconnect the part and put a new one on without having to replace the hose as well.
    Sniper:
  • 52 Answers
Yes you can. The end of the hose that mates with the suction/blower is flexible. You can use a pair of needle nose pliers to compress the hose end and force it out of the suction/blower connector.
Posted on May 22, 2010
How do I disassemble a suction blower connector from the hose on a sweeper?
Here is a walk through on installing the attachment hose, just reverse to remove the hose:
Vacuuming Bare Floor with Kirby vacuum
800-775-6586
GoodVac com
Oct 04, 2014 | Kirby G5 Bagged Upright Vacuum
Kirby g4 how to switch from suction to blower
Remove bag from canister.
Attach hose to canister where the bag connects.
It can now be used as a blower.
Jan 26, 2011 | Kirby G4 Bagged Upright Vacuum
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I'm trying to set up my vac as a blower! Help
Take the cloth bag and mini-imptor ofthe f. Then take you suction hose "that you would normaly put on the front" attach it to the side where you took the emptor off. It should lock on with a simple twist and lock. Now you have a blower. However you will need the intake guard assy. on the front of your kirby. Refer to the manual for that attachment. Good luck.
Nov 08, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby generation 3 won't vacuum. It runs and
You may have suction but if the belt is worn the roller brush won't spin and therefore won't pick up anything. You can get a replacement belt here:
http://vacbelts.xps.convina.com/kirby-301291-belt.htm
Oct 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
I have the bag unhooked and the hose connected to the motor which has engaged the safety switch but the Kirby will not turn on to blow air
Blower instructions HERE. It MUST help.
If you put it back together as VACUUM and it works with hose (attached to suction) and the nozzle - no problems with Kirby. Then you must not be turning the hose on the exhaust all the way. Sometimes it is pretty hard...Or maybe the safety sup plastic that presses the safety switch on the front of the unit is broken.
Good Luck,
Rocky
Jun 06, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Where do I connect the hose and it's attachments
You need the suction/blower connector on the hose:
This must be for G4 or G3 model as later models had this part a bit different.
For rest of the attachment go HERE.
I can sell you used FULL G4 attachment set for 99.00
Good Luck,
Rocky
Apr 05, 2009 | Kirby G4 Bagged Upright Vacuum
Hose for G3 Kirby doesn't fit Sentria
Yes G3 and G4 had different gasket thus the suction blower connector connecting Kirby hose to the unit on later models is different. You do not need to replace entire hose but just the plastic part that connects to the vacuum. You can find it HERE. To remove old connector you may have to submerge the end of the hose into hot water (not to hot to touch) so the vinyl becomes soft and you can bend it in with finger bringing plastic end over the lip on the molded end of the hose.
Good Luck
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate won't clean carpet
when you install the hose connector it trips a switch that switches the vac motor into high speed because the vac path is longer using the hose. check the belt after you remove the front. make sure the direction of rotation is in the direction of belt travel stamped in the impeller. try adjusting the head height
Aug 13, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
192 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
