Question about Kenwood KAC-5203 Car Audio Amplifier
Kenwood 350 w-2 amp wiring
I have a kenwood2 ch 350w amp hooked mono to 2 10 kicker cvr 4 ohm. they hit hard now but due to space i like the amp but would like to add another 350w kenwood(1 amp per sub) how can i do this
  • jonnylaw Mar 31, 2008
    is there any way i can get a diagram of that hookup also will that give me a lot more power working two amps like that, bridged for both amps thanks again
  • Anonymous Mar 16, 2014
    Can u show me a diagram to hook it up
    Novelist:
  • 142 Answers
You can simply take the input and connect it in parallel to the input of the second amplifier. The output of one amp will go to one speaker, and the output of the other amp will go to the other speaker.
The inputs of amplifiers are "high impedance" so putting more than one in parallel won't put any strain on the radio circuit.
Hope this helps.
Posted on Mar 27, 2008
  • Ray LeBlanc Mar 31, 2008
    The way that sound works, if you double the power, you only gain 3dB in volume. It will be noticable, but if it's kickin' good now, you might be reaching the point of diminishing returns.
    I'm not sure how to get a diagram to you through Fixya. Basically, whatever you did with the single amp, you're going to duplicate on the second amp. The only difference is that each speaker will be driven from its own amp (wired in bridged mono). If you need, I can try to put the instructions in writing. Let me know.
How to hook up two 10" kicker cvr for best sound
If they are single voice coil and are 4 ohm you can bridge your amp and run both speakers off of it so your amp sees a 2 ohm load....better bass that will hit harder....(series wiring) look it up on google....
Sep 25, 2010 | Kicker CompVR 05CVR84 Car Subwoofer
I hooked up a 2-Ohm dual voice coil 800 watt max 12" Kicker CVR subwoofer and 4-Ohm single voice coil 1000 watt max 12" Kenwood KFC subwoofer to 1000 watt Kenwood Ampilifer. After hooking it up, the Kicker...
off the same amp? you have two way different sounding speakers man. you can buy 2 identical speakers from the same company and brand and series and they will play differently every time. you have 2 speakers with nothing in common so you will hear a difference and maybe interference because of the different ohm levels.
Apr 14, 2010 | Kicker CVR12 Car Subwoofer
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
I have 2 12 in kicker cvr tryna drop to lower ohm
http://www.colomar.com/Shavano/dvc_spkr_wiring.html
Use the above site for several wiring schematics on dual voice coil speaker hookups. It will show how to wire for different impedance.
Also, I think the CVR 12's come in 2 ohm and 4 ohm impedance. See if you can check yours to determine which you have....
Jun 28, 2009 | Kicker CVR12 Car Subwoofer
How to get the best out of this amp
"google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
How to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Dec 23, 2008 | Kicker CVR12 Car Subwoofer
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
10 inch cvr kickers
Option 1 (series/parallel) = 1 ohm load
Recommended Amplifier: Stable at 1 ohm mono 4_2ohm_dvc_1ohm.gif
Dec 17, 2007 | Kicker CVR12 Car Subwoofer
Kenwood KAC-5203 Car Audio Amplifier Logo
657 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
