Question about iRiver Story
My Story freeze it shows "Updating DB, please wait" after reset - the same when i connect it to PC - only battery charges
  • 4 more comments
  • nicololey May 08, 2010
    how can i reinstall or set to defaults if i can`t connect to pc and can`t get to device menu?
    is there any combination for full hard reset?
  • nicololey May 09, 2010
    yeah, as i said, reset doesn`t work
    after all, reset hole is not on the back, it`s on the bottom, near usb connector
    have you seen iriver story before?
  • nicololey May 10, 2010
    how can i reload the firmware??
    device is not recognized by PC
    i don`t think that 3 days updating is normal
    memory is not full, it has at least 1 Gb of free space
    i removed SD card, but it still freeze
    how can i format, if i can`t connect to PC?
    is there any combination for hard reset or format?
  • nicololey May 11, 2010
    the manufacturer gave me new device, but now it has the same problem
  • 12,061 Answers
Ok all you can do is remove, and waiy 5 mins, and then replace the the battery, and see if that "resets" the unit. What that error message is telling you that the "Updating DB, please wait" means, The Data Base, (The area in memory where all the programs data storage are kept) is trying to update, but for some reason, it cannot do so. (usually because of corrupt data or corrupt RAM) So,. Unless the "Reseting" procedure,above, works, there is little that can be economically done, oneself. The only option is to return it to iRiver for repair, or replacement.
Posted on May 11, 2010
    the problem is i can`t remove battery without losing guarantee
    yeah, db is Database, maybe i have too many books on device (but it support up to 32 Gb memory cards, and i have only 5 Gb of books)
    i made a replacement, but the second reader has the same problem
    President:
  • 2,923 Answers
It appears that the software of your iRiver Story becomes corrupted.
To fix this, you need to contact the manufacturer and have them upgrade the firmware of your device. Once the firmware is reloaded, your iRiver Story should work correctly.
Thank you and good luck!
Posted on May 10, 2010
    Guru:
  • 1,049 Answers
Depending on the amount of the data you have on your device, "Refreshing Database" may take a while to finish and is a normal process when starting the device. But if you feel it's frozen, you may try the following steps:
  1. Update the firmware
  2. Remove 3rd party applications which may cause conflicts. These can slow or stop indexing if they fail to load while accessing the database or if they try and reference the DB to early
  3. Make sure that the device memory is not full, it needs a certain minimum of free space to index the files.
If none of this works, the media might be corrupted. Reformat it and then restore.
  • 2,335 Answers
I can help you with your iRiver Story.
The firmware of your device has become corrupted, but this can be fixed by reloading the iStory system software. I am in the process of uploading it here right now (and will post you the link), but if you are in a rush you can get it from iRiver here.
Just download and unzip the file, copy it to your Story, and when you turn the iRiver back on, it will reload its system software and run like new again.
I hope that helps.
    President:
  • 3,278 Answers
Hello.
There is a tiny hole on the back of the unit that says "reset" next to it. Use a paperclip or needle and poke it in the hole until you feel a small click. This should reset it.
Hope this helps.
Posted on May 08, 2010
    Genius:
  • 1,040 Answers
Dear Nicololey,
Generally this happen when the driver becomes corrupted. So reinstall your driver and application.....
If not then you can set your device to factory defaults or update your gadget's software.......
Then also problem persist then there could be a mechanical problem with motherboard or IC or usb connector port of your gadget..... So, Sorry you have to get it serviced.......
My garmin shows a computer picture and doesn't switch on anymore!
Connect it with the USB cable to a PC / Mac - does it communicate with Mygarmin.com? If so look for a software update and load it. Make absolutely sure it's connected to external power - so the battery won't die when updating. Then wait for it to restart.
If no connection then hold the power button for more than 20 seconds - this triggers the auto reset.
If that doesn't help - let it sit like this till the battery has been drained. Then try to restart while charging it.
If still the same - let it drain again and while pressing the On button, hold the lower right corner of the screen for at least 20 seconds. This will trigger a master reset - reverting back to factory mode. It will erase all user data.
Jul 04, 2011 | Garmin GPS
My nokia 3110c has got a problem of an endless updating library.How can I solve that problem? Please
First restore it and open music player,wait until updating finished if the problem persist contact nearest mobile repairing shop to flash the phone.
Aug 15, 2010 | Nokia 3110 Cellular Phone
Whenever i start the music player it starts updating..... then in the end it shows no music file found and my inbox gets empty every time i restart my mobile.... please help
Flashing of phone from mobile tech is the best solution, but before restore 'Factory setting'.After reset open music player,remember! do not press any key until it finished.
Aug 13, 2010 | Nokia 3110 Cellular Phone
When i disconnected my samsung yp-q2 mp3 it freezes
im getting the same problem as well...it crashes after i reset it and when i want to go on a particular track it would freeze...i have given up with it...gonna try and delete everything from it and try to completely restart it if i can
Feb 25, 2010 | Audio Players & Recorders
Autoamatically loading loudspeaker option and multimedia utility.
I think your phone may need a Software/Firmware update. Before doing that, try resetting the phone:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Then update the Software (sometimes called Firmware) thus:
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
May 27, 2008 | Nokia N70 Cellular Phone
Please help
Your phone needs to be reprogrammed, only a repair shop can do this for you.
-_-_-_-_-_-_-
WARNING
May 01, 2008 | Nokia N73 Cellular Phone
Stuck on nokia start up screen
Try this:
Tip! Only use one Anti Virus Application on your phone.
If the above doesn't work try another update. (it may have mis-updated).
Before updating software you should check that there's a newer version of software available.
WARNING
And obviously don't unplug the phone from the PC.
If the PC freezes during an update, you're up the creek without a paddle...
Mar 25, 2008 | Nokia N70 Cellular Phone
Formatting N95 Nokia Phone
WARNING
You could try this, but don't hold much hope:
Yes! I know, you need someone to press the ON button.
Or try:
Hard reset code *#7780#
Mar 02, 2008 | Nokia N73 Cellular Phone
N73 software update
Try:
Press * 3 send at the same time and turn phone on. Keep them pressed until the reset screen appears.
If this does'nt do it, it will need to go to a repair shop.
Feb 01, 2008 | Nokia N73 Cellular Phone
Sansa m230 freezed
Call suport at 1-866-ScanDisk. Choose MP3 and then option 3. Tell them your problem. They will have you try a few things and then send you to the retailer where you bought it for posible exchange. That is my story so far. I will be at Staples in the morning.
Dec 29, 2006 | SanDisk Sansa m230 MP3 Player
iRiver Story Logo
255 people viewed this question
Top iRiver Computers & Internet Experts
David Payne
David Payne
Are you an iRiver Computer and Internet Expert? Answer questions, earn points and help others
