Question about Canon PIXMA iP3000 InkJet Photo Printer
Problem5100 I just change my ink and my ip6310d is giving me the error 5100 and I don't have my manual to know what that means. can u help? I have the black in the left and the color in the right
  • 4,041 Answers
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
Gives me a code 5100
Canon i550 Service Error 5100 ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/25975
Oct 6, 2006 - I recently dropped my printer out of my car by accident, and now everytime I try to print something, it gives me a Service Error 5100.
Canon Pixma MX420 Printer 5100 Error and Loading Ink ...
? 5:57
https://www.youtube.com/watch?v=tmTJdJTAhYU
Mar 13, 2012 - Uploaded by Dustie Meads
please help me,i have problem in my printer,wifi on printer can't search .... I too was given the generic "5100" error message just tonight.
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Service error 5100
hiTurn on your printer
After that press: Menu - Scan - Copy - Scan.
It will enter in Service Mode.
Here I don't know exactly the procedure but may be something like that for mpc190/200 that follow:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-Scan-Copy-Copy
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
I hope this helps youRegards
Mar 07, 2012 | Canon PIXMA MP130 All-In-One InkJet...
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I got an Error Code 5100 in my Canon Pixma MX850, but it is because a paper got stuck under the print cartridges.
error 5100 is a carriage error, meaning the printer cannot find the position of the carrier. You have likely gotten some grease or ink on the 10mm wide plastic strip that goes through the carrier, just to the rear of the ink tanks. Unplug the printer with the cover open, then you can manually move the carrier from side to side and use a tissue to wipe any material from the encoder strip.
Oct 31, 2010 | Canon PIXMA MX850 Multifunction Printer
Service error 5100
5100 means the carriage is not moving properly, or there is grease or ink on the encoder strip The encoder strip is the clear strip with black lines behind the carriage that runs all the way across the printer. You can clean the strip with a Q-tip just damp with water.
Jul 28, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Canon PIXMA MP530 Error Code 5100
OK. It sounds like there's something on the carriage bar restricting the movement of the ink carrier. Perhaps some ink got on the bar.
Try taking a clean lintfree rag dampened with rubbing alcohol and clean the bar. This may have to be repeated a number of times to get the foreign matter off the bar and the ink carriage.
Let me know if this helps. iF it does not we can try something else.
Thanks.
May 05, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Low on ink. don't know how to change ink cartridges.
Heres a direct link to the download page so you can get a manual, its free. CLICK HERE
That should help you the instructions for changing ink is in there, feel free to give me a Fixya rating if this answers your question.
Jan 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Error 5100
Don't quote me on this but I think any error code over E 200 means servicing required.
Sep 06, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
74 people viewed this question
old marine
old marine
