Question about Roper RAX4233PQ Top Load Washer
Where are belts located on machine - Roper RAX4233PQ Top Load Washer
    President:
  • 949 Answers
This unit does not use a belt, if you are having trouble with agitate and spin it is most likely the coupling. Here is a link that explains what that is and how to replace it. Let me know if this helps you.
http://www.fixya.com/support/r4670549-drive_coupling_replacment
Posted on May 08, 2010
Error p 5 konica milnolta bizhub c450
IDC sensors are located under the transfer belt on the right sid eof the machine. Belt must be removed to clean sensors. Once belt is removed sensors are located on a black plastic frame and have slideable covers that can be moved by hand to clean sensors. There are 2 sensors one machine front and one machine rear.
Mar 01, 2014 | Konica Minolta bizhub Office Equipment &...
Tip
Change the belt of a washing machine
It may happen that you have to reassemble a washing machine belt (belt is being broken or simply withdrawn from its normal location).<br /> With a change thinking about ordering the same belt model.<br /> The mounting is done of a bike chain:<br /> -Placer the belt on the motor axis and a part on the pulley.<br />loyalty turn the pulley.<br />-the belt will be implemented alone.<br /> <br /><img src="nidalkom01_11.jpg" />
on Jan 10, 2011 | Washing Machines
Need to locate a belt for the Necchi 256 sewing machine
call or email these sites about a belt
sewvacdoctor.com
a1sewingmachines.com
Feb 05, 2013 | Sewing Machines
Can you tell me where the belt is located? is it from the back or underneath the washer? this is for the HE2 model 8540265. thanks
Kenmore Elite HE2 is a front load washer and the drive belt is located at the rear of the machine. It can only be accessed through the rear access panel. Disconnect power then remove the screws attaching the panel to the rear of the machine cabinet then pull the panel off. You now have an access to the rear inside of the machine where the drive motor, drive pulley, and the drive belt are located.
Jun 18, 2011 | Washing Machines
Why won't the Kenmore top loading washing machine agitate?
There are two types of Kenmore top loading washing machines. The direct drive models and the belt drive models. Direct drive models do not have a back access panel and the water inlet valve is located on the left side viewed from the rear while belt drive models do have back access panel and the water inlet valve is located on the right side viewed from the rear.
The most common problem causing a top loading machine not to agitate, particularly when the motor seems running, is a broken motor coupler for direct drive models and a broken or worn out drive belt for belt drive models.
The best way to exactly determine the cause is to access the drive motor. Open the back access panel for belt drive models and check the drive belt. Check the drive motor if it is running, humming or stuck.
Please indicate the model number of the washing machine if it is a direct drive model for the procedure in accessing drive motor.
Jan 15, 2010 | Washing Machines
MY GE Washer WCRE6270G0WW wont spin or agitate. Please help
IT SOUNDS LIKE YOUR DRIVE BELT HAS BROKEN FIRST TURN OFF POWER TO MACHINE THEN LOCATE THE SCREWS AT THE BACK PANEL AND REMOVE THEN OPEN PANEL AND LOCATE DRIVE BELT REMOVE AND TAKE IT TO A ELECTRICAL AND PLUMMERS SUPPLY STORE FOR REPLACEMENT THEN REFIT BELT TO MACHINE AND IT SHOULD WORK FINE ,.
Nov 30, 2009 | Cars & Trucks
HOW TO REPLACE A BELT ON AN AMANA LWA65AW wash machine
FIRST DISCONECT FROM POWER AND THEN REMOVE ALL SCREWS HOLDING MACHINE PANELS IN PLACE , LOCATE BELT TIGHTINER LOOSEN AND REMOVE OLD BELT , THEN FIT NEW BELT AND AJUST TENSION .
Nov 01, 2009 | Washing Machines
I need to replace the belt on my Miele washing machine. Can you tell me how to do it?
Open the washing machine's back access panel.Depending on the make and model of your washing machine,you may need a screwdriver to unscrew the screws that hold the panel up.Locate the washing machine's drive belt.It will be in clear view,detach the old drive belt.Use the screwdriver to unscrew the pump coupling.Then gently slide the old belt off of the drive belt notch.If the belt is broken,be careful not to leave any pieces in the washing machine's interior. Slide the new washing machine drive belt over the drive belt pulley in the machine.Carefully stretch the belt up and over the second pulley before releasing.Use the screwdriver to re-attach the pump coupling.Test the drive belt's tension.If it is looser,tighten the pulleys to increase the belt's tension.Replace the access panel and resume using your washing machine.
Aug 27, 2009 | Miele Washing Machines
Maytag top load washer
what is the model number of the washer
May 11, 2008 | Washing Machines
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Roper RAX4233PQ Top Load Washer Logo
35 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
