Question about HP L1706 17" LCD Monitor
My screen has an all over red hue. How can I get
My screen has an all over red hue. How can I get it back to normal?
    Sergeant:
    Champion:
  • 236 Answers
Look at the connetion pins on the vga cable
Posted on May 08, 2010
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Screen has a red hue
adjust it through the settings menu.
go to color, hue settings.
Nov 13, 2013 | Dell Televison & Video
Red hues all over the images on screen
The TV is a plasma screen. There are several circuit boards that will go bad over time that affects the picture quality. TV Parts Universal TV Stands DLP Chips ShopJimmy You can get the parts here and replace those boards yourself.
Apr 10, 2017 | Panasonic TH-42PZ700U 42 in. Plasma...
Screen turn to red hue and then back to normal
Not uncommon on this model as a lot issues with the red and most of them are caused by touchy master screen controls. The set has a black rectangular block with three screen and three focus controls, for whatever reasons the red screen control always seems to be the flaky one and usually a very tiny adjustment of that one does cure the problem.
Aug 27, 2012 | Hitachi 46F510 46" Projection HDTV
When I first turn on the Toshiba projection tv the color has a strong red hue to it which clears up gradually
I would suggest when turning set on cold---turn color all the way off and examine screen as set warms up---if red to some degree but gradually becomes black and white the issue is either a "touchy" red screen control on the screen/focus block or a problem on the circuit board plugged to the bottom of the red tube.
I guess the real question is how long until it is normal?
May 20, 2012 | Toshiba Televison & Video
MY SONTY WEGA TRINITRON HAS A PURPLE HUE AT THE TOP OF THE SCREEN. ALSO THE CHANNEL DISPLAY WHICH IS NORMALLY GREEN ON COLOR IS NOW A RED COLOR
This kind of problem occurs if tv screen got hit by some thing that damage internally and its irreparable, second possible cause is magnetic field nearby screen, please check any speaker or some thing that has magnet inside around tv, remove it from tv to fix purple hue at top of screen.
Unplug tv from AC wall socket for 20-25 minutes, replug back in and turn it On, this will demagnetize screen to cure the problem.
Apr 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Color on lcd screen changes, tap the computer
Could be either a loose connection or a defective lcd cable or lcd. Likely a bad lcd cable. ordering one from ebay and replacing it is the easiest way to tell and least expensive
Jun 27, 2009 | Acer Aspire 5920-6574 Notebook
Phillips 51" Screen Distortion
See if the issue happens in the menu alsoif not replace the small signalbaord.
Apr 25, 2008 | Philips 51PW9303 51" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
HP L1706 17" LCD Monitor Logo
170 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
