Question about Kitchen Appliances - Others
INSTRUCTION BOOKLET I can't find the address of phone number for DURABRAND. We purchased a Durabrand 4-Slice Toaster Oven-Model #T0-80. and we don't have the INSTRUCTION BOOKLET. NEED TO HAVE CONTACT WITH DURABRAND I have a Durabrand Toaster oven Model TO-80. When selecting bake mode and then temp,both heating elements light up. According to the manual only the bottom element should light up when in bake mode. Since the bake mode and temp mode are selected with only one dial, it is not obvious as to how this should work, please help
  • ToddGinaCMSG Dec 30, 2008
    how do you turn the oven part on....it has bake temps then bake setting then broil on same twist knob!!! I set on bake first then temp then vice versa...won't turn on!!! help durabrand t0-80
    Problem Solver:
  • 9 Answers
Chances are that both elements should energize when starting up in bake mode. Since bake is by the very nature of the principle "constant heat" then the job of the control on the unit is to maintain an stable temperature for a specific period of time. Sooo... when starting up, both elements would be available to quickly raise the temperature. Once that temperature is reached then the bottom element would be all that is required to maintain the set temperature. Watch the elements for a period of time, until the "bake" temp is met and see if the bottom element is the only one energizing for the remainder of the time alloted.
Posted on Apr 01, 2008
How do i Opened my cuisinart toaster cpt180
The Instruction Booklet for the Cuisinart CPT-180C Classic Metal 4-Slice Toaster can be found at the following link:
http://www.cuisinart.ca/pdf/ibs/en/CPT-180C_en.pdf
Not sure what you are trying to open. There is a slide out catch tray for cleaning crumbs. There is no information in the booklet that suggests a need or a way to open the toaster.
Perhpas reviewing the booklet will answer your question.
Jun 28, 2012 | Cuisinart CPT-180 Metal Classic 4-Slice...
Contract information for durabrand toaster oven
1st solution I can think of is to go back to the Walmart you bought it from and get a manual from another box of the same model. If that is not possible, contact me at gertzdad@comcast.net and I will copy and send you mine.
Dec 22, 2008 | Toaster Ovens
Need instruction booklet
try here. if the link does not work let me know.
http://www.hamiltonbeach.com/use-and-care/use-and-care.php
i have emailed you a copy as well
Robert
Sep 05, 2008 | Hamilton Beach 31197 120 Watts Toaster...
INSTRUCTION BOOKLET
look it up on the internet try that
Mar 25, 2008 | Microwave Ovens
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
281 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
