With the machine OFF, Press the 6 key and START and power it on. When it beeps, release the keys. A menu should appear that lets you select which items you want to reset.
There are so many answers due to not having more information, i would suggest you search tosiba laptop c850 on Google. There is lots of info there, also check out the support page at toshiba, find some of the manuals...
Beeping? Does it beep if you just try to start the system normally? Beeps and blinking lights tells the technician what is going on with your system. Count the pattern of the beeps and blinking lights (example: 1 Long Beep or 1Long beep followed by 2 Short beeps).
If it beeps when you just try to boot up normally then you have a motherboard issue.
Maybe your memory is bad. Remove the Power Cord, Remove the battery, open the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Try the following. 1. Remove battery and plug in the AC Adapter and check if it works 2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester) If lighted - it works properly if not - replace 3. Try to reinstall WINDOWS operating system by the use of the installer CD 4. If problem persist - the motherboard might be defective.
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
