Question about Eureka EL8502A Bagless Upright Vacuum
Beater brush won't turn - Eureka EL8502A Bagless Upright Vacuum
  • 8,404 Answers
Belt is probably broken ...
Posted on May 08, 2010
My XV 11 Vacuum keeps on bringing up the message " My vacuum is stuck"
This message generally means that the beater/brush bar is not turning. Try rotating the beater/brush bar manually to see if it can turn freely. If not, you will need to remove the beater/brush bar and ensure that it is clean; that the orange end caps on the brush are free of hair and dirt, and that the bar housing area is free of obstructions.
Note, when I said "beater/brush", it could be either/or, depending on whether you're using the "standard" beater bar, or the upgraded pet brush.
May 31, 2014 | Neato XV11 Vacuum
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 13, 2010 | Vacuums
My bissell helix cleanview vacuums brush doesn't spin
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
The brush roller will not engage although the belts look good. Hoover upright windtunnel.
Sep 12, 2010 | Hoover Vacuums
After installing belt...broke
Sep 12, 2010 | Bissell 3522 PowerForce Bagged Upright...
Cannot get the brush to rotate when vacuuming
Sep 12, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
THE BRUSH ISN'T TURNING, EVERYTHING ELSE IS WORKING.
Sep 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum turns on but the brush is not rotating
Most likely a problem with the drive belt or the beater brush. Either the drive belt is broken or the beater brush is frozen due to debris. If you can not turn the beater brush by hand, it should be removed and cleaned well. The ends of the beater brush that hold it into the vacuum should be lubricated with some WD40 and moved by hand until they are free. Once the turn freely, replace the beater brush. If the drive belt is broken or missing, it needs to be replaced.
Sep 10, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka EL8502A Bagless Upright Vacuum Logo
23 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
