Question about Humminbird Smartcast Rf 35 Dual Display Wrist Sonar
My 570 transducer is mounted on trolling motor.
My 570 transducer is mounted on trolling motor. the depth reading jumps from .6 to 7 feet and then stays at .6 feet
I too have the exact same problem. .6 to 6ft then stays at .6. love to figure this out.
Posted on May 08, 2010
  • jm15341 May 08, 2010
    I'm guessing that since its a Dual Beam, the sonar beam is wider and it bouncing off the trolling motor fin and propeller. So I'm going to try to lower the transducer, lower then the fin and propeller. Trade off is that it want be protected anymore by fin.
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
I need a longer power cable for my humminbird 561, is it possible
don't splice them bad bad bad call hummingbird order you a set of power cables
Apr 11, 2013 | Humminbird 561 Fishfinder
Loses the depth after around 60 feet.
Is the transducer face clean? Fouling and barnacles can cause poor depth readings. Also, a low power output from transmitter or poor sensitivity of the receiver (both internal), or a broken transducer cable connection (usually accompanied by heavy noise being painted on screen). With your ear in the water, fairly close to transducer (6-10 ft., you should hear a clear tick-tick-tick sound as it transmits on a medium depth range.. No power adjustment is available in the menus, but the unit does transmit at a slower rate, with wider (stronger) pulses on the deeper ranges.
Sep 14, 2009 | SI-TEX Sitex Cvs106lmkii Color Lcd With...
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
Mar 29, 2009 | Lowrance X135 Power Pro Sonar Without...
Mounting a sonor/transducer on a MinnKota Riptide ST
Did the unit come with a strap to mount the transducer to a bow mount electric? Most units do... If not there is probably one available for the unit as an aftermarket accessory or accessory from the manufacturer... Regarding the transducer wire, just wrap and rout this up the front of the bow mount motor shaft so when you pull the motor up and secure it, it is not going to get in the way. You could cable tie the cord down near the bottom of the shaft and one up near the top where they wont interfere with the motor bracket when the motor is positioned up on the boat.
Mar 17, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Depth sounder problem
If the transducer is mounted off of level, an error is introduced due to angle. It is a fixed percent offset, say 10%. so 10 feet reads 11 and 100 reads 110. There is an offset function to read depth below ducer, depth below keel, and depth below waterline, but these are fixed amounts in feet, not a percentage. Look at the transducer when it is operating, boat angle considered.
Jun 18, 2008 | Furuno GP1650DF GPS Receiver
Shaft
It is not recommended to cut the transducer cables as they are sensitive to outside interference.  Most trolling motors have adjustable shafts so you can set it at the depth you want. Look for a locking mechanism where the shaft attaches to the mounting bracket.
Oct 25, 2007 | Minn Kota 55 AutoPilot Universal Sonar...
Humminbird Smartcast Rf 35 Dual Display Wrist Sonar Logo
270 people viewed this question
Top Humminbird Sport & Outdoor - Others Experts
Are you a Humminbird Sport and Outdoor - Other Expert? Answer questions, earn points and help others
