Question about Samsung SF-5100 Plain Paper Laser Fax
Sf-5100 issue We can receive, but cannot send. The phone does not light up as usual when trying to fax out. (it does when we receive) Is there any way to test the actual fax machine?
    Sergeant:
  • Samsung Expert
  • 406 Answers
Kindly check the setup. Before anything refer to manual and check that you are getting a dial tone for sending in a telephone set.
Best Regards
Rafique
Posted on Mar 27, 2008
Can not receive or send fax. There is the phone tone on the BT line.
When we are speaking about faxes you have to try at least a few numbers, because there is sometimes a temporary problems with tel line speed. To send or receive the fax the tel line should be stable. Fax machine try to connect to highest speed (33,6 by default) and if the line is not stable you will receive connection error.
Try again but tomorrow or ask yout telephone company if there is a problem with line
pifonski
Feb 20, 2011 | Samsung SF-5100 Plain Paper Laser Fax
Can send but not receive faxes
No identification is not the problem. It sounds like you have it set to "manual receive" rather than "auto receive"
Jan 28, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Hpofficejet: will not receive fax. Sender is given our phone number, our phone is answered and we dial our code -- this no longer works. Cannot find manual. Do we reset the number and how, or what...
I just got a new line just for my SF-5100 fax. It was working before I switched to this phone company. I checked the line on a regular phone and it seemed ok. When I plug it up to my fax machine, when it rings I get this static sound instead of rings. One of my customers said when she tried to fax something, she got that same static sound and it would not go through. When I tried to fax her something, I dialed the number and when the fax machine was repeating the numbers it was a series of that same static sound. Then the operator said I should try my call again - so it did not dial through. A few minutes ago, the screen said RX also. Can you please help?
Oct 07, 2008 | Samsung SF 5100 Laser Printer
My SF-5100 has stoped receiving faxes
Make sure you are set for AUTO RECEIVE.
Unplug power cord and re-connect. Do you have a DSL phone line?
Sep 05, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Fax machine will send faxes but will not receive any
The normal problem with a fax that will not receive calls it the phone line.
The Line Voltage, or current may be low, or the signal ( DB loss) may be affecting it.
Let me give you an explaination. When you send, you physically connect to the phone line, make the dial tone and whatever is there, it goes out over the line.
When you receive a fax, it is like a remote control, with a remote you need good batteries to generate enough signal to turn on a product.
With a fax, you require an electrical signal, like a remote control to activate the receive capability. Low power, voltage or current. or static, will not allow it to receive, just like a remote with a bad battery will not turn on a product.
Issues can be. The phone cord between the fax and the jack. A bad jack, something on the outside line.
Using a digital phone line, or having another device on the same phone line drawing down the line, or picking up. A credit card machine, answering machine, even another phone can cause issues. If on a shared phone line, disconnect everthing but the fax and have someone send you a test fax. See if that helps.
But more than 90 percent of fax will send , will not receive issues are phone line related.
Apr 11, 2008 | Samsung SF-5100 Plain Paper Laser Fax
Can't get the machine out of "broadcasting mode"
have you tried to see if paper is jammed in side of the fax manchine this will prevent it send/receving faxes .
follow your manual instructions for this .
you could also contact samsung on the number 08707267864 8am-8pm.
riz.
Nov 20, 2007 | Samsung SF-5100 Plain Paper Laser Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
123 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
