Question about Evenflo Aura Select Travel System - Georgia Stripe Stroller
How to adjust shoulder straps - Evenflo Aura Select Travel System - Georgia Stripe Stroller
2 Suggested Answers
JMuskovitz
  • 135 Answers
SOURCE: shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Posted on Mar 31, 2007
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
How do you move the straps for a bigger child
Hi
Undo the popper on the shoulder harness pad. Slide the pad down the length of the shoulder harness strap.
Unhook the metal D ring.
Feed the short length, low down anchor point back in behind the seat fabric. Bring the longer length, higher up anchor point out at the desired height.
Re-attach the D ring. Adjust the harness straps accordingly.
Slide harness pad back up shoulder harness and re-attach popper.
Sep 11, 2011 | Quinny Buzz Three Wheel Stroller
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
I have a turn a tot car seat and the straps that hold her into the seat are to long and i can't work out how to shorten them and i can't find instructions anywhere
I guess you have pulled the harness adjuster strap tight (between the legs on the front edge of the seat) and are still left with slack shoulder harness straps. It may mean you need to remove the seat and check the harness straps are going thru the shoulder slots in the seat, then they need to go up and over the the metal shoulder rod before going down to connect onto the metal spreader plate
Dec 13, 2009 | Baby Gear
How can pull adjustment belt
The shoulder straps feedthrough a loop in the adjustment belt so when you pull on the belt it tightens the straps. When you say it came out, if it has come out completely then you will need to remove the car seat and locate where it connects to the shoulder straps before feeding it back through the hole again
Aug 15, 2009 | Maxi-Cosi Baby Gear
How do i adjust the shoulder straps to a bigger size
http://www.mountainbuggy.com/resources/uploads/documents/Buggy%20Instruction%20Manual.pdf
here you go. We had the same problem :-)
May 23, 2009 | Mountain Buggy Urban Single Stroller
Adjusting the shoulder straps on the Maclaren volo stroller
What year is your Volo. Different years adjust differently. The newer ones have 3 height adjustment slots and a slider that adjusts the strap itself. They do not adjust way down though and even with teh straps as tight as they will go, they are still a little loose on my 15 month old granddaughter. I have found that buy tightening the waist straps it does keep her a little more secure.
Mar 15, 2009 | Maclaren Volo Umbrella Stroller
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
Evenflo Discovery 5- Pink and green
you need to take the seat to the dealer for safty reasons
Mar 31, 2008 | Evenflo Discovery - Midland Blue
Evenflo Aura Select Travel System - Georgia Stripe Stroller Logo
95 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
