How to repair the laptop screen
I have a couple of time upgraded my Window XP laptop to Window Vita. The Advent 7092 Laptop screen gone damaged. I also tried to put back my window XP back and the screen is still damaged. Still working and showing some red lines on screen but was not before like that.
Can you give some advice how to repair the damage screen.
Thanks
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
I think is not the upgradation problem may be screen only , connect external monitor and check if it ok, problem in laptop screen
Posted on Mar 27, 2008
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
May 20, 2012 | Advent Computers & Internet
Ive just upgraded to windows xp professional and my wireless or sound isnt working on my laptop its an advent 7037 every thing else works but wireless and sound doesnt can you ask me whats happened
Your laptop is made by Medion. Follow this link and type MD40672 at the "full text search" field, like this:
You will come to a page with all the drivers for your laptop. Choose the required drivers and download them.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 21, 2011 | Computers & Internet
I have an acer laptop 5532. My someone tripped over the cord and pulled it off the table onto the floor. Now when I turn it on all I get is a black screen. Can it be easily fixed or should I be shopping...
Well there might be several problems but I hope if there are no serious damages visible then it might be worth to repair. Probably laptop has been accidentally disconnected from screen so I recommend you to go for any laptop repair shop and ask them for solution. Tell them what do you think it might be and they will sort problem for you. If screen is not damaged then there might be only connectivity problem which is easy to repair even yourself. In my mind there is no reason to buy new laptop
Oct 25, 2010 | Advent Netbook
Closed advent laptop with earphone in between and damaged screen .can it be repaired?
You will have to get the display changed and this is the tough part as the cost might need an estimate.
So check this out with the dealer as there is no other option.
Sep 28, 2010 | Recoton Advent Advent Q2035A 20" TV
Advent Milano Elite: Changing the desktop background
A typical laptop battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Aug 03, 2010 | Advent Netbook
R60e model 0657 came loaded with XP Pro and was upgraded to Vista business(free upgrade fron IBM)I need to reinstall the laptop but cannot locate the rescue/recovery partition. How can I create a recovery...
Recovery Disk are free kit from your IBM Laptop but gone.
Supposed to be used for installing system or repair.
This time if you don't have, your going to buy a Bootable XP or Vista Pro its the same with your Recovery Disk CD.
If i am helpful please rate me.
Thank You.
Yboyandrei
Aug 15, 2009 | Computers & Internet
Change to XP settings
is it a laptop or desktop. if it is a desktop it will prolly load XP, if its a laptop, it prolly wont...
Feb 27, 2009 | HP Pavilion dv1000 Notebook
Laptop gone dark
This sounds like a burned out backlight lamp.  Had that happen to a Mac laptop used at work:  all the boot-up LEDs and sounds occurred, but a dark screen.  It was fixed promptly by our computer guy, who is pretty amazing at fixing computers.  So all I can tell you is that it shouldn't be a particularly expensive repair.
Jun 09, 2008 | Recoton Advent Advent Q2035A 20" TV
How to repair the screen of Advent 7092 Window XP version. Help Please!
This may not be damage, it could be the wrong driver.
Go to the control panel, look at the device menu to see if the display is possibly marked as not working correctly.
Then look at the display settings to see if new driver alternatives have appeared.
Incorrect drivers can damage a display; I've seen it happen (unfortunately).
Mar 27, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
