Question about Ovens
I spilled water on the oven, and the monitor showed F1, then there was a bang sound. like a small explosion. do you know what was that?and what component is broke ?
  • Dan Webster
    Dan Webster May 11, 2010
    Is this gas or electric? what brand?
  • 187 Answers
F1 is normally related to the electronic controls for the oven. It is located behind the clock and touch controls. It sounds like the water hit an open electrical connection. You have not said whether your oven is gas/electric.
If it is electric and you spilled water on the element, senor, or other electronics inside the oven, it is highly likely that is the root of the problem.In a gas oven, it may be the ignition or sensor. Inspect the area that you spilled the water on, look for black spots or light spots on the elements, sensors and wires. The control may have tripped due to a sudden irregularity in power. You have not said whether your oven is working at all, so it is difficult to guide you further. If you would like, leave comments with more information. Thanks for using fixya.
Posted on May 08, 2010
Why when i changed the oven bottom element now it seem to stay red all the time and gets very hot beeping sound and f1 on display
What's ur oven? Ur oven has a heater relay.. K4/k5 relay controlling the heater. It's a small square shape.. Try to trace back the wire..
Jun 08, 2016 | Ovens
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
I cannot use the oven
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2010 | Kenmore 47712 / 47714 / 47719 Electric...
Range developed problem while cleaning oven
Your electronic oven control is bad and must be replaced.
The clock.
Mar 15, 2009 | Ovens
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven fire, loud explosion sounding like a welding torch,flames. Very nervous!
Most likely an element burning out though it does sound a little more excessive than is the usual case. Was the fan oven on, in which case remoce the inner ear panel in the oven and check to see if the element surrounding the fan has burnt out
Oct 21, 2008 | Neff U1721 Double circotherm Electric Oven
Beeping sound showing f 1
HI thanks for your question. F1 means that the touch pad is faulty. it says to replace the touch pad. thanks .please rate my answer thanks.
Oct 07, 2008 | Jenn-Air JJW8530C Expressions Collection...
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Ovens Logo
257 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
