Question about Garden
The blade will not engage on our L130 John Deere riding mower..the wires are not loose and do not appear to be broken. The seat switch works and the reverse switch works. Is there an another fuse, other than the main fuse? THanks...
  • 1 more comment
  • lhalfin May 08, 2010
    The ohms and volts both read 0...does this mean we have a bad coil?
    How many fuses are there on this model mower? THanks...
    Thanks...we will have to take the mower in for repair, but the assistance was helpful.
    President:
  • 2,468 Answers
Do you have +12 volts at the clutch coil?
Posted on May 08, 2010
  • danny Hendrickson May 08, 2010
    it means 0 ohms that the clutch coil is good,but 0 volts means you have an open circuit somewhere,try a jumper wire direct to the coil,if it engages then use your volt meter to back track where your losing the +12 volts to your coil,it may very well be a fuse,which could mean the coil is good,but shorting out to the frame and blowing the fuse
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
Nov 26, 2016 | John Deere Garden
I have a John Deere 355d lawn tractor. Every time I engage blade or release brakes the mower dies out. Checked safety seat switch and its not that.
Try pulling up on your PTO switch to engage the RIO switch. If it works then there is a problem with the reverse switch is located near the directional pedals/linkage or on the transmission. Attached is a picture of the switch from the John Deere parts catalog and a wiring diagram.
Feb 13, 2016 | John Deere Garden
Why won't my 2007 John Deere L130 turn over?
remove spark plug and see it it turn over .set Brake too
May 04, 2015 | John Deere Garden
John deere l130
Likely a bad switch. Could be one of three switches that will kill the engine when pto is engaged. First is the reverse switch, next is the seat switch ( operator presence switch), and lastly ( and least likely) is the clutch switch.
Sep 01, 2014 | John Deere Garden
Mowerdeck will not engage...
I own a similiar John Deere model (L130, 23HP with a 48" deck). I would check the electric clutch (called a PTO). To do this check the wires to this clutch and look for something disconnected. These wires (to this PTO clutch) should have twelve volts with the key on and the blades engaged.
Feb 26, 2011 | John Deere 195HP Hydrostatic 42" Cut...
John Deere L130 blades will not turn and the PTO will not engage.
I am having the same problem. Mine is the PTO switch wires that are breaking at the connection to the clutch just above the belt pulley that is under the engine. I have fixed mine several times, because there is so much vibration.
Aug 15, 2010 | Garden
Serviced my riding lawnmower runs great. but when I put in drive it dies out. Also when I engage blades it dies out. No problems last summer. It won,t stay running when I do these two steps
Probably the seat safety switch. If it's not activated (from your weight on the seat) the engine is killed when you put it in gear, or engage the blades. Lift up the seat and check the switch - wires on tight? switch tightly mounted? You can take the switch out and tape it in the pushed-in position to test things. If that doesn't let the mower run, the switch itself is probably bad, but it could also be a connector that knocked loose when you serviced the mower. Check wires and connectors. Good luck!
Jun 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere L130 riding mower...while cutting the blades just quit turning...have checked the belt and the blades will turn by hand but won't engage with the switch
There seems to be a common problem with the L130. After reviewing the posts it appears that many people are having this issue. I had the same problem, it turned out to be the wires from the PTO switch at the clutch under the engine (right above the belt pully). The wires are breaking at the connection under the engine due to the vibration.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Oct 02, 2009 | John Deere Garden
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
