Question about LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive
Lacie hard drive will not work on my tv, the tv said mode not surported
  • 416 Answers
1. Did the device Support Before?
2. Have you checked if the Device Works on a computer, if the device works fine, then i am afraid, you TV does not support the External HDD. This could be Software or Hardware.
Posted on May 08, 2010
Upon start up I see the icon on my screen but then disappearing and reappearing along with all my other icon. the Lacie is disrupting my entire desktop & when I shut it down (Lacie) everything goe
I think the problem is because mounting problem of the logical drive .In this case to access your data in the drive you just need a macbook hard drive recovery tool .Remove the drive from your pc install the drive in some other mac pc and start it in target mode .Install this recovery tool and start recovering files but save it in different healthy drive .I am suggesting this tool because it works good for my missing partition problem.But purchase the full version to get good results.The demo version link is here...
Feb 03, 2012 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
I just recently purchased this hard drive and it must be in read only mode. it is only reading 10mb, how would i get it out of that mode?
There is no such mode on external hard drives.
Have you tried it on another computer? Did you format it when you first used it?
In windows, go to Device Manager, Click on Disk Drives, double click on the Lacie drive. Check the Volume information and see if it shows the full size.
You may need to re-partition and format the drive. If you do not understand how to do this then it is safer for you to get someone experienced to help you.
Feb 18, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I was copying an avi file from the 250GB lacie porsche hard drive (USB2) and the USB cable got removed while the copy was in progress. I tried restarting the computer but the hard drive isnt regonised. it...
hi.
maybe problem is caused by your Power supply.
so i recommend you to do these:
1- remove the main hard drive and only connect "250GB lacie porsche hard drive".
and see is it recognized or not.
2- go to the bios (with pressing "delete key" at start of turning on) and navigate to power center.
then enable power saving mode.
Jan 29, 2011 | LaCie (300728U) 250 GB Hard Drive
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
When I put my mac in sleep mode and restart it I get a message that says I have not put my lacie hard drive away right. How do you do that.
The message you are getting is refering to removing the Lacie before disconnecting it.
Just as you eject a drive before unplugging the cables to prevent corruption you must do the same before going to sleep as turning off the power to your USB ports(which happens in sleep mode) is no different than unplugging the drive without ejecting the drive when the computer is running.
If your Mac is set to go to sleep and save power when it is not in use then you should only plug your Lacie in when you are using it and should eject the Lacie before going to Sleep.
Failure to do so will eventually result in a loss of data.
If you have already lost data from a Mac formatted Lacie drive then you should refer to the below link for assistance in recovering your files, if not simply follow the above steps and you should not have any problems as a result of your Mac going to Sleep.
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Feb 11, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
LaCie silverscreen Utilities CD-ROM
The OS is hidden in memory, you can clear all files off the machine and it will still work.
The only requirements are the 4 folders:
Firmware
Movies
Music
Pictures
That's it!
New firmware can be found at www.lacie.com
Dec 24, 2007 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Lacie 1tb external hard drive
As a precaution, backup your data to another machine, in case the external drive is developing problems which would get worse and essentially "lose" your data. Does it do this on other machines other than yours? If so, it is developing problems, which, as said, could be deadly to data. If it doesn't foul up on other machines, then something is afoul with something on your machine. Various problems are reported with sleep mode wakeup. Could you disable the sleep mode function? You might see if there is an O/S update for your Mac which addresses this problem (waking up the USB ports & connected devices).
Sep 15, 2007 | LaCie d2 Extreme 250GB External with...
LaCie Hard Disk 1TB Desktop with Hi-Speed USB2.0 USB 2.0 Hard Drive Logo
195 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
