Question about Toshiba Office Equipment & Supplies
I need to print more than the last 40 transmissions from my Toshiba Facsimile. How do I do this?
    President:
  • 3,085 Answers
Not possible.
Posted on May 08, 2010
I do not want a Communication Result Report after each fax is sent. How do I turn this report function off?
This is a somewhat complicated change. You must change the user parameter "switch" to turn the automatic printing of the transmission result report off. If you have your Facsimile Reference Manual "Advanced Features" then just go to the user parameters section and go thru the steps. If you do not have your manual you can download for free here.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Be sure to get the advanced features facsimile manual.
Sorry for the referral to a manual but you will see what I mean, it is just too much stuff to type here and the manual has pictures of the display as you go.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Ricoh Aficio 1515 Black and White Copier
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Ricoh 4420L fax machine
Go to www.ricoh-usa.com
Click "Downloads"
Click "Download Ricoh manuals"
Under "Facsimile", click the drop down
box, highlight 3310LE, click "Go".
Download both manuals.
In the Advanced manual, page 84, shows the
settings to turn off or on memory or immediate
transmission result reports.
Jul 13, 2009 | Ricoh 4420L Printer
Need instructions on customizing Transmission Verification Report
Terry,
Please send me your email address...I can send you the Facsimile Guide in PDF formatt pages 11-11 and 11-12 provide Tx Report Settings.
tswiercinsky@yahoo.com
Jun 03, 2009 | Canon Laser Class 8500 Printer
How do you turn off the in use/memory light?
This of course depends on why the light is on! If you had a fax come in and it is in memory, you will need to print the fax and clear the memory before the light will go out. The LCD Display should be telling you why that light is on.
1. There is a fax or print job in memory waiting to be printed.--> See steps below
2. There is a paper jam --> Open printer - Remove all paper - Close printer - press OK button
3. You are out of ink or the cartridges are low. - Change Cartridges
Solution: Printing reports and lists MX310
The table below shows the reports and lists that can be printed from your machine.
Report or List Description ACTIVITY REPORT Shows recent facsimile transactions performed by your machine. You can enable or disable automatic printing of this report after every 20 transactions. You can also manually set the machine to print it. CODED SPEED DIAL
LIST
Lists the destination numbers and names registered for coded dial speed dialing. USER'S DATA LIST Lists the current settings of your machine and the registered sender information. MEMORY LIST Lists the documents currently stored in the machine's memory. TX (Transmission)
REPORT
Prints after transmission of a document.
You can enable or disable this feature, or set the machine to print a report only when an error occurs.
You can also set the machine to print the first page of the document under the transmission report to remind you of the contents of the document.
RX (Reception)
REPORT
Prints after reception of a document.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Mar 24, 2009 | Canon PIXMA MX310 All-In-One Printer
How can i get a fax from memory.
Printing reports and lists The table below shows the reports and lists that can be printed from your machine.
LIST
REPORT
RX (Reception)
REPORT
Confirmation that a fax went through
Hi:
If the fax was not set up to give a confirmation report for every transmission then the next best thing you can do is use the journal. If the fax has a journal key then just press that and it should print out the last 40 to 50 TX'x and RX's for you.
Andrew
Mar 19, 2009 | Canon PC-1060 Black and White Copier
Discontinue fax transmission report
Press;
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
  • OK
  • Exit
  • User Tools/counter button
Good luck and please rate me, thanks.
Jan 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Cant send a fax with Toshiba Facsimile 4700
Plug a regular phone into the wall jack and listen for the dial tone.
Jul 30, 2008 | Toshiba Office Equipment & Supplies
18 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
