Question about GPS
On my 1994 lincoln town car I set the wheel on the dash at a slow speed for the blower but in a few minutes it blows at full speed and turning the wheel doesnt slow it down
  • 10,319 Answers
Inside the dash is a programmer that controls the settings you set. That programmer needs to be replaced since it will not hold the setting you have set for the blower speed
Posted on May 08, 2010
    Genius:
  • 1,040 Answers
Dear Cbhegge,
It is a software problem. So First try by setting your device to factory default. If problem persist then reinstall your software......... if then also problem persist......... Then sorry you have to get it serviced............
Speed control set/accel won't engage 1996 lincoln towncar
I have a 2001 lincoln an when i try to set the cruise the light will flash but it will not set ?
May 15, 2012 | 1996 Lincoln Town Car
2000 Lincoln town car. Heater fan is full on at full on position. Any other setting the fan is off. No speed control.
When one or more speeds on your heater/AC aren't functioning, the problem is usually the blower motor resistor. It's usually located near the firewall on the opposite side of the heater core.
May 03, 2011 | 2000 Lincoln Town Car
How to fix 1999 lincoln TC heater/AC fan speed. Speed is intermittent or not blowing at all. Fan sometimes blows at full speed then may start to turn on and off. Sometimes it does not blow at all.
You have a problem with the resistors on your blower motor. 95% of AC/Heater blower motors are located under the glove box in the passanger foot well. When you remove the motor you should see a resistor plate. Resistors are not servicable and will need to be replaced. This is a relatively cheap part, that you can replace yourself if your handy, if not take it to your local tech.
Nov 13, 2009 | 1999 Lincoln Town Car
Cannot control my AC blower on my 2001 Lincoln
sounds like your switch contacts are shorted closed.. try disconnecting the switch for inspection and use a volt ohm meter to inspect switch across contacts...
Sep 11, 2009 | 2001 Lincoln Town Car
1994 lincoln town car air suspencion
I have a 94 Lincoln Town Car, I had same problem. Go to Strutmaster web site. Print info and have your Mechanic remove air suspension & add strut kit.
Jun 26, 2009 | 1994 Lincoln Town Car
1994 Lincoln town car/ no fan control on ac and heat
I aasume you mean blower motor for heater/a/c system.
Does it work on hgih speed only? If yes, replace resister.
Is this manual a/c or electronic?
Here is circuit for manual. check these three fuses first. 1, 17 & 10 in fues panel behind dash or kick panel by driver's knee.
If you have electronic, you may have a bad "blower motor speed controller". Get used at car-part.com. page with asterisk is lowest price. New at tascafordparts.com
Jun 16, 2009 | 1994 Lincoln Town Car
Shifter linkage bad on 1994 lincoln town car
so i went to the mechanic and it turns out theres a few bolts under the steering wheel under the dash one of mine fell out causing the gear shifter to become loose but the hard part was taking the dash apart thats all it was and thankfully it was an easy fix
May 29, 2009 | 1994 Lincoln Town Car
96 lincoln town car ac fan doesn't blow
check the blower motor relay and resistor.
May 20, 2009 | 1996 Lincoln Town Car
95 Lincoln towncar stuck on high temperature setting
u need a new blend door motor. this is a job 4 the machanic cause the whole dash must be pulled back
Mar 25, 2009 | 1995 Lincoln Town Car
GPS Logo
24 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
