Question about Sony KP-57WS500 57" Rear Projection Television
My sony tv model kp57ws500 its turn on for 15 second and trurn off and red led is blinking,
  • 7 more comments
  • chetansoni18 May 08, 2010
    5to 8 times i think
    My TV KP57WS500 Turns on , has Blue Strip and turn off, has red led blink about 3 times and off, then 5 times and off, then 6 times and then off, this is reping 6 time led blinks . let me know what is problem so I can order parts.
    its not that light reguler blue strip , and then turn off, tell me the parts # so I can order plesas ,
    Thanks, Chetan
    its blue ( Blue pata in hindi if you Indian then you can undestand) strip roling and then turn off, its blue buttons on browser right now( like submit Ask)
    As soon as I turn on tv, its bling with blue strip and then tv turn off , then the red led blinking 3, 5, and 6, 6, 6, times regulerly while tv screen is off, I am computer tech but I did the sony tv power board change to my other tv and its works. I am trring to find out with this tv (my Father In-lows) try to save some mony.
    Thanks Chetan
    Guru You need to help me out pls.
    its littel curv with bright blue
    I am not at home,
    I think as you meson its blue picture tube is going bed.
  • 10,594 Answers
Red led blinking is error code, please count its blinks and let me know.
There would be 3 seconds long pause between blinks so count pause to pause.
Thanks.
Posted on May 08, 2010
  • 4 more comments
  • Shahid Electronics
    Shahid Electronics May 08, 2010
    5to 8 times i think
    OK, 5 times blink shows problem with any picture tube in this tv as it has 3 picture tubes to make color picture.
    6 times blink is next error code that shows over current protection and cause would be same picture tube that consume much current due to problem.
    Qualified tv tech is needed to replace defective picture tube in this tv.
    Thanks.
    can order parts.
    Blue strip?
    Do you mean high bright blue screen comes then tv shuts down?
    If thats the case that means blue picture tube is defective.
    Thanks, Chetan
    Does tv show bright blue screen with few thin lines (retrace lines) across the screen before to shuts off?
    Please confirm above symptoms to provide you blue picture tube part number.
    Thanks.
    like submit Ask)
    OK, if you have experience of tv repair then adjust Screen Volts of red and green tube, there is focus block that has 6 control knobs, 3 knobs for focus and 3 for screen volts, and this focus block is located on front lower side, please remove front speaker grille to get access to focus block.
    You need to increase little bit screen volts of red and green tube.
    Can you post blue stripe picture here?
    I'm still confused on word "blue stripe"
    Yes, it seems blue picture tube got bad but I need to see tv picture to confirm it.
    You can post picture later when you get back to home.
    Thanks.
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
Standby timer blinks times
There are particular blinks meaning on sony TV. I can give you the problem from your sony tv if you specify or count how times the LED flashed.
Jul 06, 2014 | Sony KV-27S42 27" TV
Code for sony tv
Make sure your TV is on.
press "TV" on your sky remote
hold down both "SELECT" and then "RED" button until the little LED blinks twice on your sky remote. (should be for about 2 seconds)
press "TV" again
enter the code "0000" on your sky remote
the little LED should blink twice again. (if it didnt, restart the process)
if it had blink twice, then press the "STANDBY" button on the sky remote - your TV should turn off. (if it didnt, restart process again)
if it did - press "SELECT" the little LED should blink twice again, and hey presto - you is programmed wink.gif
Apr 25, 2013 | Radio Shack (15-2147) Remote Control
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
Feb 17, 2009 | Sony KDS-50A2000 50" HDTV
RED LIGHT
Does the light blink?
there is a
Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 07, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony Kp-65wv700 Too much red -- white looks redish
fix the red:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 01, 2007 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Sony KP-57WS500 57" Rear Projection Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
