MF5700 making clicking sound after moving machine
I have a model MF5700. I moved the machine to a new location, plugged unit in and now it wont stop making a clicking sound. the machine defaults to scanning mode and continues to make this clicking sound. any suggestions?
  • 4,234 Answers
There should be a microswitch at each end of the movement so that the machine knows where the end is. I would suspect that one of those switches is damaged. What you are hearing is the toothed belt slipping over the gears. This needs to be repaired before the belt snaps.
Dan
Posted on Mar 27, 2008
SOURCE:
After moving to a new location the refrigerator makes a noise after being plugged in. It sounds like it's trying to turn something or move something inside and it is stuck or not spinning properly. What...
The compressor is tripping on high head pressure, or is seized. Make sure the fan is free of debri underneath the unit, make sure it is cleaned out. If it still wont start, do not leave it on. Unplug it. It is possible the compressor start capacitor coincidentally failed.
Nov 02, 2013 | Washing Machines
I went to plug my bread maker in Model B2500C and it started making a funny noise. Then I moved it to a different area to see if it would work better. When I plug it in it automatically starts and won't...
These are fussy models and have lots of issues - if you are still covered under warranty just contact B & D, they were great at sending me a new model after mine broke under warranty. It sounds like yours is broken beyond repair, it is likely cheaper to replace it. Try contacting the company, they should be able to help you best.
Sep 07, 2013 | Black & Decker Bread Machine
Wont start
there is a loose connection/open curcuit on the cable. connect a multimeter on the plug connector an select the ohm scale to check resistance. move the wire and see if the value changes. if it does, replace thec able from sensor to control unit.
Jun 14, 2013 | Android Apps
Kenmore model 2495-4301. When closing the lid to begin any cycle, there's a metal clicking sound coming from the area of the bottom. The agitator will not move in any cycle. Just that clicking sound..
I had a similar problem with my washer. It was clicking, but the agitator was moving fine. The clicking was coming from the centrifugal switch. After checking the capacitor I was about the give up and call a repair tech. Then I noticed the Speed Selector was set between Delicate and Normal. I moved the selector to a proper position and the washer stopped making the clicking noise and is working correctly.
Feb 08, 2011 | Kenmore 24952 Top Load Washer
After freezer was moved not getting cold
Unplug the unit and leave it undisturbed for 24 hours. Plug the unit back in again and see if it will come to temp.
Jun 02, 2009 | Freezers
Hayward pool cleaner wont move
Make sure the feet have springs in place, move freely, and rubber not too worn. If that all looks ok, then probably too much suction pressure. Use gauge that came with unit to verify proper suction.
May 30, 2009 | Hayward Navigator Pool Cleaner
Need to disassemble Whirlpool Ultimate Care II washer
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LSQ9564J
Click on the model that matches your machine.
The new window will give an assembly diagram of your machine. Clink on the diagrams on the left-hand side for different assemblies.
Mar 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Touble re-fitting transfere unit
At the back of the printer where the transfer unit locates is a white plastic cam. This has probably moved a few segrees and you just need to rotate it back into position before you can locate the new transfer unit.
Jan 09, 2009 | Epson AcuLaser C900 Printer
Open Questions:
Malwarebytes tEch SUpPoRt $1 855 536 5666 $ pHoNe nUMber CGJ* Malwarebytes tEch $O1/855/536/5666$ SUpPoRt tMICo resolve all Malwarebytes Antivirus products. Malwarebytes Antivirus is an American multinational company which was founded by Michael Malwarebytes Antivirus using its company headquarters in Round Rock, United States of America.Contact Malwarebytes Antivirus for Setup & Installation Malwarebytes Antivirus Setup Support & Installation Malwarebytes Antivirus Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Malwarebytes Antivirus Connect, Malwarebytes Antivirus Helpline Phone Number you'll be searching out Malwarebytes Antivirus Connect setup as well. So, here we're with all cthe setup process and for your to Malwarebytes Antivirus Connect. Get Malwarebytes Antivirus Setup Instant Support Malwarebytes Antivirus Customer Service Phone Number Usually, the setup Customernique takes a number of time. One Customernique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may Malwarebytes Antivirus locate the approaches simplified to help you even if you aren't Customer savvy. Let us undergo the method Of Malwarebytes Antivirus Connect setup for Windows and for Mac Out. So, Outright here we go vikki
Oct 16, 2019 | Carrier Computers & Internet
Arlo tEcH sUpPoRt pHoNe @#[1845=481=1722] Number Netgear Arlo Security Camera Tech support Number EMAIL +[{1\845:-481-1722*}]Wireless Repair service center to resolve all Netgear Arlo Security Camera customer service phone Number products. Netgear Arlo Security Camera is an American multinational company which was founded by Michael Netgear Arlo Security Camera using its company headquarters in Round Rock, United States of America. Contact Netgear Arlo Security Camera for Setup & Installation Netgear Arlo Security Camera Setup Free & Installation Netgear Arlo Security Camera TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Netgear Arlo Security Camera Connect, Netgear Arlo Security Camera TECH Free Phone Number you'll be searching out Netgear Arlo Security Camera Connect setup as well. So, here we're with all cthe setup process and for your to Netgear Arlo Security Camera Connect. Get Netgear Arlo Security Camera Setup Instant Free Netgear Arlo Security Camera TECH FREE Phone Number Usually, the setup TECH nique takes a number of time. One TECH nique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Netgear Arlo Security Camera Connect setup for Windows and for Mac. So, right here we go vikki TALATUM
Oct 16, 2019 | NetGear Computers & Internet
Computers & Internet Logo
50 people viewed this question
Ekse
Alun Cox
