Question about Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and
How does the cap assembly rp4993 come off, or do you have disassembly instrutions you can email?
    Scholar:
  • 102 Answers
The part number rp4993 I believe are the seats and springs for Delta faucets. Be sure to turn off the water before you begin. If you are working on a Delta, I am guessing a single handle. Then once you have removed the handle, the bonnet or cap should be exposed. There is a little grooved section that goes around the bonnett that you can grip with pliers or a pipe wrench. It should unscrew counter clockwise. Once this is off you can remove the ball and seats and springs to replace. I hope this helps.
Posted on May 27, 2010
Trying to replace agitator dogs. Removed cap and nut, and have whole agitator assembly in hand(one large unit). However I cannot get the dogs out, as the inner assembly won't fall out. How do I...
See the following illustrated descriptions:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=bb1287f031ea458c3a91d1feb88faaa8
Nov 03, 2010 | Washing Machines
Mossberg 800 bolt disassembly instructions
TO DISASSEMBLE BOLT - Depress Safety
Cap' Lock Plunger #8 and turn Safety Cap
# 1 counterclockwise. Striker Spring #9
and Firing Pin Assembly #10 can then be
removed.
TO REASSEMBLE BOLT - Replace firing pin
assembly and striker spring. Insert safety
cap and turn clockwise making sure that it is screwed forward as far as it will go. Then unscrew
until the hole for the safety cap lock plunger is in line
with the cam slot in the bolt. Drop lock spring and
plunger into hole and face cut out portion toward bolt.
Depress plunger and screw cap clockwise until the
plunger is engaged in the recess in the rear of the bolt.
Oct 26, 2010 | Mossberg Sport & Outdoor - Others
How do you tear down front hub on 4 wleel drive truck?
FRONT DRIVE AXLE Manual Locking Hubs DISASSEMBLY AND ASSEMBLY Fig. 1: Three screws retain the cap to the hub body 91197g48.gif
Fig. 2: Remove the lockring seated in the groove of the brake rotor assembly 91197g49.gif
Fig. 3: Remove the hub body assembly from the brake rotor assembly 91197g50.gif
  1. Raise and safely support the vehicle.
  2. Remove the wheel and tire assembly.
  3. Remove the three screws retaining the cap and remove the cap from the hub.
  4. Remove the lockring seated in the groove of the brake rotor assembly.
  5. Remove the hub body assembly from the brake rotor assembly. To install:
  6. The installation is the reverse of the removal.
Oct 12, 2010 | 1997 Ford F250 SuperCab
Toolcaddy instrutions to small to be seem on steamcleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
5trae
Oct 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replace damaged screen apple iMac
If You want to make it yourself and You nave iSight model - be prepared to fighting with disassembling, it's not so easy and more - after assembling You can get it non-operate. Best way is a service center. But if You're sure - I can email You disassembling manual. Sincerely.
Sep 14, 2009 | Apple iMac G5 Desktop
Whirlpool gold quiet partner 3 wont drain.
The new garbage disposer comes with a plastic cap in the drain port. Disassemble the drain pipe assembly and remove the cap/plug.
Jan 13, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
Delta T13420 Chrome Classic Single Handle Monitor Pressure Balanced Tub and Logo
257 people viewed this question
Top Delta Home Experts
Mike
john h
Tim Whalen
Are you a Delta Home Expert? Answer questions, earn points and help others
