Question about HP DeskJet 960c InkJet Printer
My HP Deskjet 960c will not print all colours. It usually will not print yellow but sometimes it will not print cyan. I have changed cartridges but it makes no difference.
  • hamish535 May 09, 2010
    Many thanks for your comprehensive reply. Unfortunately, this has not solved the problem. It must be something else that is causing it.
  • 4,041 Answers
Hi There
A good clean up you may need to do this more than ones maybe.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
I used machine's ink jet cleaning program, without luck. Cyan and Yellow still don't print. What next?
My HP printer has a cleaning programme and a cartridge priming programme. I had trouble with my colour cartridge, in particular the cyan. The cleaning cycle never worked but the priming programme worked a couple of times but whenever the printer was left idle for a while the colour would not print.
I took the cartridge to a refill shop and the guy emptied the ink and steamed out the cartridge and print head and refilled it and then it did work for a time.
A new cartridge is expensive and so these days I just use it for printing black...
I think there must be something strange or different about the cyan ink. Sometime in the future I am going to try steaming again only this time with a deal more pressure than the guy at the refill shop used.
I am sure it will be kill or cure...
Deleting the printer and reinstalling it should be the next step to try. Sometimes my printer goes a bit eccentric or gets in a bad mood if I try and pause or cancel printing from the printer menu. I have learned not to do that with any HP printer. Once it gets in a bad mood the only cure is to disconnect it from the mains and leave it for half an hour before plugging in again.
My printer, incidentally, is a Deskjet 96 Cxi professional machine. I like it because it prints both sides of the paper and it cost me nothing.
Mar 06, 2016 | HP Officejet Pro L7580 All-In-One InkJet...
Colour cartridge prints in b&w only
Please follow the following steps.
1) Turn off the printer.2) Shutdown the PC to which the printer is connected.3) Remove the USB/Serial cable through which the printer is connected to the PC and reconnect it back.Now replace the color cartridge with a new one.
4) Now switch ON the PC(only PC and not the printer)5) Let the PC boot up and login to windows.6) Now switch on the printer, PC should detect the printer automatically now.
Nov 24, 2011 | HP DeskJet 960c InkJet Printer
Printer is printing yellow instead of red and colour is fade
The magenta has run out (red).
Replace the HP 22 tri-color cartridge.
It probably has yellow and cyan (blue) left in it, and the black is most likely working as well, but if any of the 3 colors in the tricolor cartridge run out, the whole cartridge must be replaced.
For instance, if I printed my vacation photos and there was a lot of water and blue sky in all of them, the cyan might run out long before the cartridge life expectancy.
Also, don't forget that cartridges are rated in pages printed at 5% coverage.
Since a photo is about 25% of a full page, a photo printed at full bleed (edge to edge) will only yield 32 4 X 6 inch photos from a cartridge rated at 160 pages (5X expected coverage = 1/5 the prints)
Mar 27, 2011 | HP DeskJet F380 All-In-One Printer
Hello, My HP 932C has suddenly started printing photos in pink. I have tried cleaning all the cartrdge contacts, reinstalling the software, a new cartridge. No change. Any ideas?
Your cartridge may need to be replaced. If your tri-colour cartridge has run out of yellow and cyan and only has red left this could be the cause.
Jun 08, 2010 | HP DeskJet 932c InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
My hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
May 09, 2009 | HP DeskJet 1280 InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Hp deskjet 960c
You say it stopped working mid-print... possible paper jam? Ink cartridge not clicked in all the way? (they should all line up evenly across the tops).
In control panel->printers and faxes, right click on Canoni960 and choose properties. In maintenance tab try to do nozzle check and print head alignment. In lower right corner is status monitor, click to see if any useful information in there.
May 17, 2008 | HP DeskJet 960c InkJet Printer
Colors Murky... HP DeskJet 1120c
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
May 11, 2008 | HP DeskJet 1220c InkJet Printer
HP DeskJet 960c InkJet Printer Logo
225 people viewed this question
Seeker5211
Seeker5211
