How to repair the screen of Advent 7092 Window XP version. Help Please!
I have a couple of time upgraded my Window XP laptop to Window Vita. The Advent 7092 Laptop screen gone damaged. I also tried to put back my window XP back and the screen is still damaged. Still working and showing some red lines on screen but was not before like that.
Can you give some advice how to repair the damage screen.
Thanks
  • 5,569 Answers
This may not be damage, it could be the wrong driver.
Go to the control panel, look at the device menu to see if the display is possibly marked as not working correctly.
Then look at the display settings to see if new driver alternatives have appeared.
Incorrect drivers can damage a display; I've seen it happen (unfortunately).
Posted on Mar 27, 2008
SOURCE:
Ive just upgraded to windows xp professional and my wireless or sound isnt working on my laptop its an advent 7037 every thing else works but wireless and sound doesnt can you ask me whats happened
Your laptop is made by Medion. Follow this link and type MD40672 at the "full text search" field, like this:
You will come to a page with all the drivers for your laptop. Choose the required drivers and download them.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 21, 2011 | Computers & Internet
Advent Milano Elite: Changing the desktop background
A typical laptop battery of tests, including games, applications, and a couple other areas. Time constraints limited the amount of testing we could get done before the NDA lift (and it's already a few hours late), but we will be providing a follow-up article with further testing and information. That said, if there are any specific areas that you'd like to see tested, feel free to e-mail me or leave a comment.
Aug 03, 2010 | Advent Netbook
How do i run windows xp prof service pack 3 keeps saying sawpidll cany be found
It seems that the installation of your window xp service pack 3 through the device might be corrupt please try a different alternative or you can upgrade the xp professional if you have older version.
May 09, 2010 | Computers & Internet
Acer aspire 5600. Did a system restore and the computer would not start the windows programme then stopped trying and comes up with 'ntldr is missing' and won't get past that. Any advice would be much...
Sometimes the only way to repair XP is to reinstall. You do not have to wipe your partition and start over. Just as with previous versions of Windows you can reinstall right over top of an existing setup. This has the advantage of retaining your installed applications, data and settings. You will lose previously saved System Restore Points but System Restore will begin creating new restore points again immediately following the Repair Install. You will need to reinstall SP2 and any Critical Updates from the Windows Update Site. Be aware that a Repair Install will leave your system vulnerable to the Blaster and Welchia worms. Do not go on line until you have enabled XP's firewall first. Then visit the Windows Update Site to patch your system It is always prudent to backup important data before you make changes to XP. There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade.
1-Boot with the Windows XP CD and at the Setup Screen press the Enter Key
2-You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed
3-
The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
***CAUTION*** if you do not see the option to repair the selected Windows XP installation DO NOT choose the option to continue installing a fresh copy without repairing as that will overwrite your data and cause unrecoverable data loss.
Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
When Setup has completed you should find all of your previously installed apps and settings are intact.
Feb 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
Laptop wont play cds but will play dvs
Maybe its beacuse its not the right type of drive for your notebook. Did you maybe upgrade your program ? That happend to me before. i had to geta friend to help me fix it . Try downloading a dffernt version or getting a new program.
Feb 21, 2010 | Computers & Internet
Where has the Free Download of AVG 8 gone?
The free version has upgraded to 8.5 as well. Just do a Goggole search for "Free AVG" and you'll get the download link
Apr 13, 2009 | RTO Avg Anti-Virus & Anti-Spyware 8 for...
E:\i386\winntupg\netupgrd.dll
http://www.fix-all-dll-errors.com/netupgrd.dll/
You can get the new dll from here...just follow the link & this will fix the problem :)
Mar 22, 2009 | HP Media Center PC 873n (P9875A#ABA) PC...
Xp is not offcial
Please expalin.
I know you can Upgrade to XP at a discount from NT (actually it works from any pervious version of Windows to XP) but there is no Update from NT to XP.
I've been doing IT work for a long time, and I am a registered Microsoft Partner, and I have never heard of an Update to XP.
If you do mean upgrade to XP, here's how I would do it.
Get a copy of XP (preferably Pro, the upgrade version is fine, and you can still fine it a number of places). What they don't tell you about upgrade versions is that it is a full copy of XP, that just have a sequence that need the previous key to continue.
Use the XP disk to format, and begin the load.
During the install, it will ask for the qualified version of Windows you are upgrading from. You put in the NT CD, and it will continue the install (you just have to swap CD's back and forth a couple of times).
The previous version does not need to be installed.
If the NT is the only disk you have, and you don't want to purchase the XP upgrade, there is a whole process that you have to go through.
You do have to create 3 floppies that have the boot and load sequence.
This is not a real user friendly install, but it can be done.
I personaly would spend the time and money to find a copy of XP. Here again, your end product is going to be something you are much happier with.
Aug 18, 2008 | Compaq Armada M700 Notebook
Computer froze
Yes, it does. Try this:
How to Repair Install: ***Also removes Service Packs***
There are two approaches. The first one should be used if you can still boot to your Windows Desktop. Simply pop the XP CD into the CD-Rom drive and select Install->Upgrade[recommended]. This will install XP overtop of itself in the same way as upgrading from a previous setup. However if your version is an OEM version then you will not have this option. If you do not see the option to Upgrade[recommended] DO NOT choose New Install as that will either overwrite your current setup completely or give you a dual boot setup. Also if you have an older version of XP and have upgraded to a new service pack you will get a message stating that a newer version of Windows was found and you will not be able to run the Upgrade. Create a Slipstream version to solve this problem
If you cannot boot to the Desktop, or you have an OEM version of XP, or you want to remove a service pack then the following should be used to complete a Repair Install.
You will be taken to the Windows XP Licensing Agreement. After reading the agreement press F8 to proceed.
setup02.jpg The next screen gives you the option to do a fresh (clean) install or to repair the selected Windows XP installation. To run a Repair Install Press "R" at this time.
setup03.jpg Windows XP will copy the necessary files to your Hard Drive to begin the installation and will then reboot. You will see the message that informs you to "Press any key to boot the CD". Do not press any keys this time just wait a few seconds and the Windows Startup Screen will be displayed. Following this you will be greeted by the Windows XP Setup Screens.
setup05.jpg rc%20017.jpg setup06.jpg When Setup has completed you should find all of your previously installed apps and settings are intact.
Jul 17, 2008 | Dell Inspiron 8600 Notebook
How to repair the laptop screen
i think is not the upgradation problem may be screen only , connect external monitor and check if it ok, problem in laptop screen
Mar 27, 2008 | Computers & Internet
Open Questions:
Dell Printer support phone number +1=855=536=5666+ Dell Printer Customer Service QEFKEFU Dell Printer assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Dell Printer helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. Dell Printer TeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... Dell Printer Tech Support Phone Number +{1-855*536*5666*} to resolve all Dell Printer products. is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .Dell Printer CUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL Dell Printer CUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. Dell Printer CUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Dell Printer is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Dell Printer care number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Dell Printer tech support pHoNe {18555365-666-}} nUmBeR USA Dell Printer tech support pHoNe Number {18555365-666-} to resolve all Dell Printer products. Dell Printer is an American multinational company which was founded by Michael Dell Printer using its company headquarters in Round Rock, United States of America. Dell Printers Support Phone Number for Dell Printer Technical support help. Dell Printer Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 16, 2019 | Dell Computers & Internet
Computers & Internet Logo
75 people viewed this question
Ekse
Alun Cox
