Question about AEG B5741-4 Electric Single Oven
OVEN WILL NOT OPERATE
WHEN I TRIED TO USE THE OVEN (NEW OVEN, FIRST TIME USED)AN F4 CODE APPEARS. WHAT IS THE PROBLEM. NO INFORMATION IN USER MANUAL
  • 269 Answers
F4 is a fault with the temperature sensor for the oven which normally will need replacing.Hope this helps.
Posted on May 08, 2010
Testimonial: "Thanks for your help. All other avenues of enquiry were unsuccessful."
After a pyrolitic cleaning cycle, an error code F04 has appeared and the menu does not want to start any more.
Miele fault code f04 Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > fault code f04 > Ovens
Miele ovens fault code f04 related questions and answers. ... Can't use my Meilepyrolitic oven fault 90 I turned it off at the main power source and then ... fault 23 is displayed on the control panel after using teh self clean function on our miele ...
[PDF]USE & INSTALLATION MANUAL - Smeg
www.smeg.com.au/smeg_au/docs/user_manuals/DOA330X.pdf
Smegelements or interior surfaces or racks of the oven during or immediately after use. During the oven ..... locked automatically due to self-clean mode. "USER LOCK" is ...These codes are displayed when the electronic control detects a ...... The ovens feature a pyrolytic self-cleaning function ..... F03 or F04 Error appears.
[PDF]user manual e:line built in ovens - Appliances Online
manuals.appliancesonline.com.au/epee63cs/epee63cs.pdf
Jan 10, 2016 | Ovens
What do I do about oven beeping?
Could be control module, but not sure. I had issues with a code a long time ago, and the broiler kept coming on and wouldn't shut off, so finally had to shut it off at the breaker. Turns out the control module is fried. But just a thought.
Apr 28, 2015 | Kenmore Double 27" Electric Built-in Wall...
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
The oven keeps beeping code F4.
Hi
F4 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 05, 2011 | Amana AOCS3040 Electric Single Oven
Error F4
Hello there:
whenever you get this error code F4 or even the f3 error code this is telling you that the ovens temperature sensor/probe is faulty and is unable to sense the temperature of the oven correctly.
So the fix for this is to get a new sensor OK SO IF YOU WILL GIVE ME THE MAKE AND MODEL # OF YOUR OVEN I CAN SEND YOU SOME PART INFORMATION ON THIS OK?
best regards mike
Jan 11, 2011 | Ovens
Older Ge F4 error Code
Your oven temperature sensor is bad and must be replaced.
Feb 28, 2009 | GE JTP85 Electric Double Oven
Jen Air jjw9530bab F4 code
HI thanks for your question. the code F 4 means an open temp sensor. which is located in the oven , top left corner. replace the oven sensor. thanks the appliance doc. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air JJW8530C Expressions Collection...
G.e electic profile slide in oven
All three codes, very odd, f3 f4 pertain to oven sensor short, or connection issue, f5 also asks to check resistance of sensor , so id try replacing oven sensor. sort probe located on top left or right side of oven cavity, 2 screws hold it place(sometimes youget lucky and will remove from front, if not you need to remove back panel and unplug and replug new sensor.cost for part can be $40-100, depending ion model
Feb 24, 2008 | Ovens
Kenmore double oven f4 fault code - door locked.
We had the F4 problem and called Sears repa. They sent someone out. The guy opened the panel above the bottom oven (we have a double oven) and hit a reset button - then charged us $75. This has worked on several occasions (my husband did it after that). But then that didn't work and Sear's told us it was the electronic panel which they replaced twice. Now it's (F4) happened again on the top oven only on a brand new electronic panel. So I guess it's the heat sensor this time.
Dec 31, 2007 | Ovens
PROBLEMS WITH FR ERROR MESSAGE APPEARING
Mewood What part did you call "thermostat"? If you?re talking about the device which operates the oven temperature, your oven does not have such thermostats. It has two oven temperature sensors (one in each oven) and a control board (ERC). An error code "F4" will be displayed along with a beeping sound if the ERC determines an open oven temperature sensor circuit. It can be the sensor itself or the wires that connect the sensor to the ERC. The F4 message will not be displayed in the time of day mode. To get access to an oven sensor and wires, the oven has to be removed from the cabinet. Then you have to remove the rear cover. Then unplug the oven sensor and check the resistance across the oven sensor. It?s supposed to be about 1100 ohms at room temperature. If the resistance is incorrect, the sensor is bad and needs to be replaced. If not, check all the wires from the oven sensor to the ERC. If it is not the sensor and wires, you have to replace the ERC, but most likely the problem is with the wires and/or connections. Part number for ERC is 62965, part number for oven sensor is 62593. Gendos....post back.
Dec 14, 2006 | Dacor ECS230 Epicure Stainless Steel...
AEG B5741-4 Electric Single Oven Logo
324 people viewed this question
Top AEG Ovens Experts
ashburton
Sal De
Steve
Are you an AEG Oven Expert? Answer questions, earn points and help others
