Question about McCulloch FH140A Electric Pressure Washer
No pressure McCullough pressure washer has no pressure after siting all winter. I took apart the assembly and the oil leaked out, also I noticed yhe o-ring that seals the two pieces together seems to have been blown out. Where can I get parts and oil. Thanks for any advice.
3 Suggested Answers
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
SOURCE: McCullough pressure washer
I nedd a manual for a FHH18A pressure washer
Posted on Apr 13, 2010
Tip
Pressure washer
I have repaired hundreds of pressure washer pumps.( Winterizing)Always tip up pressure washer to get out most of the water.Then purchase pump armor.This is like anti-freeze.If not available use light weight oil.(mineral oil is o.k.Tip back washer and pour a little in.Then pull motor start cord a couple of times and your safe for the winter.
on Oct 17, 2010 | Garden
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
WL660700AJ Problem building pressure
You either have a big leak somewhere or, more likely, have a problem with the reed valves in the head or the piston/cylinder is damaged. You can take the head apart to check the valves and piston/cylinder assembly. Parts you may need are the valve plate assembly, Part#WL211201AJ, Piston/Cylinder assembly, Part#WL211000AJ or the entire motor/pump assembly, Part#WL212000SJ.
Jul 20, 2012 | Campbell Hausfeld Air Tools & Compressors
Leaking handgun karcher k785
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. !!
Feb 19, 2012 | Garden
Oil leaking from within body of washer after half hours use and after switching off.. Oil is clean.
This is noticed on the Karcher washer and does not need any attention unless you are having a large spill over or leak. The oil oozes out when the pressure washer works for some time and is a result of a pressure leak when the washer is used for sometime.
I had seen this happen on mine for sometime , checked on all sides for any damage but there was none. So ignored but cleaned off the leak and was not seen then.
Mar 30, 2011 | Karcher Pressure Washer Gun 91120200...
Apr 07, 2010 | McCulloch FHH18A Electric Pressure Washer
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
McCulloch FH140A Electric Pressure Washer Logo
50 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
