Question about Shimano Deore LX Mountain Bike Front Derailleur - Top Swing - FD-M580 - IFD
Height of front derailuer and set up
Bought a second hand bike that has never been ridden. merely bought and put together and then garaged. The front derailuer is in bottom chain wheel which is about 22 teeth and does not change ito middele or top chain wheel.
Howard
    Brigadier General:
  • 8,546 Answers
It sounds like something amiss in the shifter. Start here and look around. It may get you to a solution.
http://parktool.com/repair/readhowto.asp?id=75
Posted on May 08, 2010
2002 Yamaha SR 125 wiring diagram
Hi, Sonny for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "Free" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2002 Yamaha SR 125 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
Yamaha SR125 1997 Service Manual Free
DOWNLOAD Yamaha SR125 SR 125 Service Repair Workshop Manual Download... $9 1997-2003
OEM parts for Yamaha
YAMAHA SR125 Owner Manual
May 22, 2017 | Yamaha Motorcycles
How to replace front cable shimano comfort 050 ?
Put the bike in the lowest numbered gear, put chain on smallest spocket/chainring. Disconnect cable from derailuer, pull cable, then replace with a new one by following steps in reverse. For detailed pictures, go to Utube or sheltonbrown .com.
Sep 01, 2014 | Shimano Cycling
Left hand indicators not working aprilia rs 125 1996?
Hi, Anonymous I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/1996+aprilia+sr125
Jan 02, 2014 | Aprilia Motorcycles
18 gears on bike, 1-6 ok hi to low faulty ie 2,.3 ok is get down to 1 witch is the lowest will not go all the time
Gday thisis usually an easy fix.
firstly i would clean and lubricate the derailuers (sounds like the front one is the problem) then once its clean and moving freely set the rear derailuer into gear 3 or 4 and the fromt derailuer into the middle cog (ie the chain should be on those cogs) then adjust your cable to remove slacknes but not so tight as to move the derailuers. Hopefully this will solve your problem
Good Luck.
**** Woodman
www.bikesbymike.com
Aug 05, 2011 | Cycling
Poulan pro front wheel drive 22 inch mower. With height adjuster set to highest level, right front wheel keeps slipping out of the adjuster notch. Is there an adjustment screw somewhere?
Is the height adjuster tight on both sides? if loose the bolt holes may be elongated, both sides set the same? any wheel wobble indicating worn out wheels?.if it checks out as good put the machine an a known hard level surface such as a garage floor and check the clearance by turning the wheels by hand without putting pressure on them, If the wheel still slips the mowing deck may be warped or bent. if all wheels are original there shouldn`t be a question of mismatched wheels ie:different sizes.
Jul 03, 2011 | Poulan Pro " Pro" Self Propelled Mower
3rd Di2 install and first 2 worked perfectly. On this bike when on big ring big cassette (23) get pretty good chain rub on front derailuer. Have tried setting tail of derailuer in more than usual and...
Derailleurs are mass-produced and are essentially identical to each other, so unless damaged it's unlikely to be the derailleur. A sticky cable could keep the derailleur from trimming properly. It also can lead you to think it's tight enough when it is not. Otherwise it's hard to diagnose remotely. Derailleur must be both at proper angle and height to shift well, cable both move freely and be at proper "tension."
Di2 Shimano Electronic Intelligent System Installation
Apr 15, 2017 | Shimano Dura-Ace 7900 Di2
Cpi sm 50 engine has been rebuilt. i have fitted new auto choke,new battery. carb has been stripped and cleaned, slightly bent the float to allow more petrol in thinking the bike might be starved of...
Hi Gusowz, put the throttle needle and float height back to their original position, I am sorry you can't find the first and best tool you ever bought for your Aprilia but despair not for a mere $10 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
https://www.tradebit.com/filesharing.php/search/0/aprilia+rx+125+motorcycles
Sep 05, 2010 | Aprilia RX 125 Motorcycles
Hello there! My mom just bought me a $300 Schwinn Melee from a Fred meyers in Newport Oregon. Beautiful Bike However there wasn't any instructions about the Shimano gear shifters. I'm doing something...
first identify the problen is it front or rear derailuer.secondly bike shop mechanic hate cheap mass produced bikes because they do not sell them
so lets solve your problem,okay sometimes this can be an adjustment issue.now if its bunching on front then first read your owners manual to see which gears are compatible,sometimes it will suggest not using certain gears,secondly if yhe chain has fallen off and got jammed it may be bent and need replaced visually confirm if the chain is straight.okay if it is not the chain then the length and length adjustment can be changed using the adjustment on the rear derailuer look and you will see 3 screws located on it the two with L /H are for adjusting the gear stops l is for low gears,so it does not go too far and wedge between the gear and spokes,H is for the small gear(high)if it goes past and falls off adjust this one.lastly the one located at the very rear adjusts chain tension the loosening of this one will relax the chain and apply more chain on the gears   tightening of this one will tighten the chain,adjusted properly your chain should not bow down over adjustment will cause chain skips.now if there is too much slack in the cable that is adjusted by the adjusters on the ends of the cable where it meets the shifters,learning to adjust your bike will save you a lot of money in the long run.
hope this helps
Jul 14, 2010 | Schwinn Cycling
Shimano Deore LX Mountain Bike Front Derailleur - Top Swing - FD-M580 - IFD Logo
199 people viewed this question
Top Shimano Cycling Experts
Michial Gueffroy
John Egan
John Egan
Eric Hidle
Level 1 Expert
Are you a Shimano Cycling Expert? Answer questions, earn points and help others
